figuring out shim size for valve springs
hey guys, I had a chance to pick up a spare head for my 2.5L. Only problem with it is it's apart, so all shims are in the bag and so on, from my understanding there are different clearances for some valve springs.
Does anyone know how I can measure that clearances so i can insert right shims in the right places.
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 01-02-2008, 08:38 PM
your average wrencher...
machine shop is your best bet, or if you have a tool to measure installed spring height which a machine shop could order you. but first you must find the spec. also does the 8v 944 have hydraulic lifters because I know my S does.....but my 924 i could manually adjust valve lash with a turn of a screw....safe bet is to check with a machine shop first
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 01-03-2008, 11:37 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
The 944 does have hydraulic lifters. I'll have to look in the manual to see what the spring tension is suppose to be. Then you can set the shims to get the proper spring tension. Do you have a different number of shims than valves. I seem to remember mine had one per spring but it's been a while since I had it apart.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-03-2008, 04:07 PM
fast924S's Avatar
Send a message via AIM to fast924S
Thats odd, I didnt see any shims when I did mine, Its just a hydraulic puck that takes up the space. I changed over to 951 valve springs for the JME camshaft
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-03-2008, 05:19 PM
Nobody Special
Are you talking about the base washers under the springs that come in either 0.5mm or 1.0mm? I believe they are used for adjusting the finished spring heights. Are yours all 1 size? If not then you'll need to measure your spring heights again and match them as best as possible. New springs are the way to go if you can afford them. Dan I sent you a PM with the shop manual instructions. I don't think I'm allowed to post them even though I own the hard copy manuals.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 01-03-2008, 06:20 PM
