Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Need Fuel Pump NEXT DAY AIR
Im in a pickel. I went out to my car when i was called out to a medical call for the fire dept. my car wouldnt start. i was low on fuel but not enough to be out of gas. cant turn the car over. i did notice that i donot hear the fule pump any longer. i really need one fast. if you can help, please let me know. i have paypal. may as well do the filter too if you have one.
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 01-02-2008, 09:03 AM
Rockin' NW Arkansas
Update
ok..... car started. runs fine. it may have just been out of gas. it took a while for fuel to get to the motor. i actually killed the batt so had to charge that back up. started after a few cranks.
Matt
Old 01-02-2008, 09:24 AM
DarylJ's Avatar
Send a message via AIM to DarylJ Send a message via Yahoo to DarylJ
1.) DME relay. Did you check it?
2.) Fuse #9. Did you check it?
3.) http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_FULinj_pg3.htm#item15
Daryl
85.5 944 Status:
[ ] running [X] broken
Old 01-02-2008, 09:25 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Wouldn't be the fuse or it wouldn't have started later. Matt, I would suggest that you carry an extra DME relay in your glove box. Order one from here and then just carry it with you all the time. The other thing that came to mind was maybe you have some water in your gas tank which is pretty normal and if it's cold when you tried to start it, either the fuel pump may have been frozen or your gas line may have been blocked by some frozen water in the tank. Buy some fuel additive to remove the water from your system if you think that is the case.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-02-2008, 06:16 PM
DarylJ's Avatar
Obviously.
Look at the post times between when he said he got it running and when I posted.
Daryl
85.5 944 Status:
Old 01-03-2008, 08:07 AM
Sorry if that bothered you...wasn't my intention as I didn't notice the times. Thanks for pointing that out.
Tom
Old 01-03-2008, 10:15 AM
