-   -   One of these things is not like the others (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/385318-one-these-things-not-like-others.html)
TNT25169 01-02-2008 10:04 PM
Here is a reminder to get your belts changed and tensioned. The timing belt broke here and a valve smashed into a piston causing all sorts of chaos. The top of the piston is missing a chunk and has a hairline fracture across it while the bottom half broke into about a million peices inside the cylinder wall. Here are a few pics. of the bottom of the piston and the biggest chunk.
http://forums.pelicanparts.com/uploa...1199340203.jpg
http://forums.pelicanparts.com/uploa...1199340226.jpg
http://forums.pelicanparts.com/uploa...1199340255.jpg
rb101 01-03-2008 03:10 AM
ouch! How many miles was on the belt? I have about 25K on mine now and I's starting to thinking it's about time to change it.
TNT25169 01-03-2008 05:55 AM
I don't know, I got the engine from someone else with a broken belt.
Razorback1980 01-03-2008 06:49 AM
I've seen several engines with broken belts but never one that bad. It usually just bends a valve. Good reminder though.
Rick, I think most here change belts around 30,000 or so and then retension after the first 2000 miles.
TNT25169 01-03-2008 07:44 AM
When I removed the oil pan there were shards or piston on the top side of the oil pick-up. I knew that was a sign this was going to be ugly. At least now I have a paper weight and an anchor....
moorepower 01-03-2008 10:29 AM
A little JB Weld and it'll be fine. :eek:
I think 3yr/36k miles is pretty safe for a timing belt.
Z-man 01-03-2008 03:14 PM
Oh my!
fast924S 01-03-2008 06:21 PM
I think its broken
TNT25169 01-03-2008 06:27 PM
She'll buff out....I think....I'm going to build a race motor for a 24hr race and I'm thinking I can save some serious weight if I can find 3 more just like it....
2Tight 01-03-2008 07:10 PM
Wow that's really ugly. The difference between a cast or forged piston is what breaks or bends first. ;)
http://forums.rennlist.com/upload/carnage6_copy8.jpg
TNT25169 01-03-2008 08:31 PM
not straight....
JHinOH 01-04-2008 07:28 AM
Wow, cool paper weight Jon, NA or Turbo?
mr. dude 01-04-2008 09:18 AM
Ouch... That takes the cake as the worst timing belt failure I've seen!
TNT25169 01-04-2008 11:20 AM
N/A...Hey Jeremy, you want this short block to work on? hehe.....
mr. dude 01-04-2008 12:21 PM
lol... Hey Jon, I think I'll wait till you have another one available.:D
dangerous 01-05-2008 10:30 PM
Same here...never seen that but I have heard of it happening every now and then.
