-   -   Jumped Chain How Bad? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/385906-jumped-chain-how-bad.html)
nynor 01-06-2008 04:10 PM
bad.
idontknow 01-06-2008 05:39 PM
Ok I give, how bad is it?
nynor 01-06-2008 05:44 PM
very.
bholmes 01-06-2008 06:24 PM
As in jumped timing belt? Did it jump or break, neither is good, breaking is worse. with a jumped belt you can fool yourself into thinking you can replace the belt and you'll be ok....that is until you do and it still turns out you bent the valves. either how, i'd probobly pull the head and inspect the valves and pistons, even if you jumped time, it's possible to damage the valves and pistons. Usually the pistons survive, but better safe than sorry. So that's where i would start. Or you can just be lazy and put a new belt on and then pull the head when/if it doesn't run. best of luck and keep us posted!
hpservertech 01-06-2008 06:39 PM
What exactly is the question?
bearone2 01-06-2008 07:54 PM
jumped what chain?
Marcone 01-06-2008 10:04 PM
I was told that the turbo can break a belt and not suffer much damage due to the low compression..
am i very off?
Razorback1980 01-06-2008 10:50 PM
Sorry to hear that nynor.
nynor 01-07-2008 06:05 AM
notice that it wasn't me that started the thread. somehow, the original poster was able to start a thread with a title but then didn't have any text. my turbo is fine, as far as i know. i injured my shoulder, so i haven't started it in a few days.
Techno Duck 01-07-2008 06:52 AM
am i very off?
The 951 still has an interference motor and the valves will still make contact with the pistons. You may not bend as many valves, but your still bending them.
Porsche-O-Phile 01-07-2008 07:23 AM
Compression has nothing to do with it. If the belt breaks, Mr. Valve gets friendly with Mr. Piston and bad things happen.
Expect (in addition to the time & labor to replace the belt) to replace 8 (or 16) valves, possibly one or more of the pistons, possibly having the block re-honed if anything physically breaks off and rattles around in the cylinder (usually not, but possible). Also possible damage to valve seats. It can get fairly ugly fairly quickly.
idontknow 01-07-2008 01:21 PM
951s had sodium filled valves, correct?
If they were, I'd bet they'd be more prone to shearing off rather than just bending like your regular valves would. Bent valves = bad, broken valves = worse.
Porsche-O-Phile 01-07-2008 01:26 PM
Yes. The exhaust ones anyway.
Razorback1980 01-07-2008 08:16 PM
Oops sorry Nynor.....
nynor 01-07-2008 08:43 PM
no worries, its an odd post.
