-   -   need part numbers pls (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/387318-need-part-numbers-pls.html)
adrian jaye 01-14-2008 07:16 AM
My home PC is down and no access to my PET's etc.
can anyone confirm part number for the following
Belt Rollar KIT
Front End Seals KIT
for 91 S2 Cab
I was told there is a "KIT" available if not individual part number would do fine
many thanks
juVius 01-14-2008 09:40 AM
here's the page with rollers:
http://www.pelicanparts.com/PartsLookup/HTML/944_2_USA_KATALOG/103-12-Frame3.htm
Techno Duck 01-14-2008 09:40 AM
Kits are not available directly from the dealer, you need to order everything individually.
There are a few retailers that sell everything in one package however. 944Online, Paragon, Lindsey...etc.
Cam idler pulley - 944.105.241.02
Balance shaft idler - 944.102.277.06
Balance shaft tensioner - 944.102.025.07
Balance shaft belt - 944.102.219.04
16v timing belt - 944.105.323.02
16v timing belt tensioner - 944.105.631.10
You also need the proper seals, waterpump, oil pump drive sleeve..etc.
adrian jaye 01-14-2008 10:05 AM
thankxs all,
one site on line PORSCHESHOP (uk)
do a FULL BELT KIT (16v)
includes cam and balance belt,
cam & balance belt tensioner,
cam & balance shaft belt idler roller.
so trying now to work out what I need to get extra?
I dont need a water pump, my indy has checked that
juVius 01-14-2008 10:08 AM
i saw that there are also some kits just like you're looking at on ebay.
adrian jaye 01-15-2008 08:07 AM
thankxs all,
sourced full belt kit 16v
and full front engine seal kit
Porscheshop, £351 inc. vat+post
