-   -   New 968 Custom Engine w/ Pressure in Coolant (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/389650-new-968-custom-engine-w-pressure-coolant.html)
Rasta Monsta 07-08-2008 07:02 AM
Originally Posted by nynor (Post 3735050)
if i fill mine to the max line, it will just leak out of the tube when it gets hot. then it stays just above the minimum line. my friend's 944 does the exact same thing
You and your friend should have a little get together and read your 944 Owner's Manuals.
:rolleyes:
flash968 07-08-2008 08:01 AM
cap pressure on a 968 should be 18-19lbs
nynor 07-08-2008 10:45 AM
:rolleyes:
ok, i'll bite... what does it say?
Rasta Monsta 07-08-2008 11:25 AM
I'll give you a hint. . .it says how much coolant should be in the tank when the car is cold.
nynor 07-08-2008 03:29 PM
if its full, its full.
flash968 07-08-2008 04:08 PM
it will be fuller hot than cold, hence filling to full when cold can result in enough expansion to force the excess out of the system - you have to allow for the expansion, and not fill it to full when cold
nynor 07-08-2008 04:27 PM
yeah, i got that. i am not really worried about stuff coming out of the overflow, as long as it the level stays where it needs to be. i was hoping that the other poster might have some esoteric knowledge to share.
Rasta Monsta 07-08-2008 04:39 PM
Just teasing you man. The manual says to fill it to MIN when cold. You aren't the first person to fill to MAX and wonder why coolant keeps coming out of the overflow. . .
