There you see larsz! But did you clean the poles, clamps and "lubricated" them with silicone grease or vaseline before reconnecting them? It is absolutely vital for a good function all the time.
---------------------------------------------------------------------------------------------- Lapponia |
There you see larsz! But did you clean the poles, clamps etc and "lubricated" them with silicone grease or vaseline before reconnecting? It is absolutely vital for a good function of a carīs electrical system. Also, check if rain or washing water is running down from windscreen onto the battery positive pole. There should be a protective lid over it. Othervise water gets into the connection and corrosion occur within a short time.
--------------------------------------------------------------------------------------------------------------------- Lapponia |
I did not put the battery back in yet but will do all those preventative tips that you reccomended though. I will post again on the results. Thanks again for your advice. Much appreciated & the car too! |
They make a real inexpensive red spray at the auto parts for corrosion or you should use dielectric grease. Glad you found the problem. Probably not a bad idea to check for battery drain, but hopefully there won't be a problem there.
Update on how the car ran. I took it down to get the car aligned & it ran great there & even better after the alignment. No electrical problems or non start so far.
basically all radios have 3 connections. Dont run directly to your battery. Run it to the fuse panel and 12v switched. Remember, your radio has a clock & station memory so it is going to draw some power when not on, should be very, very small though.
Ground 12v+ Constant (usually red) 12v+ Switched (usually yellow - connect to a wire that only turns on when the key turns on) other then speakers that's really all there is to any radio setup. You may also need to connect the ant. power for the antenna amplifier. There are more wires you can connect like the illumination, but most dont (I never have with any install), amp, pre-amp out, etc. let me know if you need help in this area. |
Just glad you have it fixed larsz. I would also recommend going through a fused power source and hook it up as the manufacturer recommends. There are many folks here that know the stereo stuff better than I do, so hopefully hpservertech's advice on the stereo will help you connect it properly. Doing it properly is important.
do the windows, horn, and radio work?
| All times are GMT -8. The time now is 02:11 PM. |
