-   -   Quick question about auto trans. indicator (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/390511-quick-question-about-auto-trans-indicator.html)
dietrich 02-01-2008 12:37 PM
Hello all, I have an 85.5 auto. On my instrument cluster there is PRND21. Should there be a light by it to show what gear I'm in? If so what does it take to fix it? Regards Dietrich
Razorback1980 02-01-2008 03:18 PM
Yes, there is suppose to be a light to show you what gear you are in. The problem is probably the "paper clip" that attaches the switch to the gearshift. If you look in the center console a wire clip attaches to the gear shift lever and a switch lever. As the shifter moves front and back, the switch lever moves with it and changes the light on the cluster. Bet you want to know the part number of that broken wire don't you? Can't remember but I'll look it up for you.
Razorback1980 02-01-2008 03:26 PM
Thanks to LiveWireVooDoo:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/280182-auto-shifter-contact-spring.html
