-   -   Part Number for AFM (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/390896-part-number-afm.html)
rporzio 02-03-2008 07:33 PM
Part Number for AFM
Hello, What is the part number for the AFM that belongs in a 84 944?
Are they interchangeable with other years?
Thanks, Ralph
Luis de Prat 02-04-2008 03:21 AM
Part number for the 1984 AFM is 944.606.121.00.
From 1985 onward the number changes to 944.606.121.01.
I believe they are interchangeable, except for the Turbo and 944S2 versions.
944 Ecology 02-04-2008 03:45 AM
Bzzzt... not quite interchangeable.
The 84 is only interchangeable with the 82-85/1 AFMs, *unless you change the DME at the same time*...
rporzio 02-04-2008 04:11 AM
Part Number for AFM
OK, how do those numbers translate to the Bosch part number? Is this a correct AFM for my application 0280 202 084...1984 944? Thanks, Ralph
944 Ecology 02-04-2008 04:45 AM
Should be this... 0 280 202 028
rporzio 02-04-2008 04:53 AM
Part Number for AFM
So the 084 will not work?
944 Ecology 02-04-2008 07:02 AM
The 084 will not work.
