My last stand!! Please let me know if im correct
Ok, this is my last shot at getting the porsche running. There is no spark, not at the coil and not at the plugs obviously. The Tachometer does NOT bounce when i turn the car over. Is it the reference sensors that are bad? If so i will order two of them from paragon tomorrow. Is there a quick way to test them.
Here were the symptoms before she finally quit last week: Monday, driving at 60mph, sudden loss of power, then regained power, then completely stalled. I stopped and she restarted and didnt do anything wrong for the rest of the time i drove it which was about 15 minutes. Monday afternoon, stopped to fill up gas tank, she started then died immediatly and wouldnt start for 5 minutes. Tuesday morning, 35 degrees outside, 6:30 in the morning, i start her and she back fires and grunts and will hardly idle then die, VERY VERY LOUD( neighbors complained ), after 10 or so minutes i finally got her to start and idle, if i gave it any gas it would want to die and grunt and stall. Then when she warmed up she ran fine unless i started driving on the freeway and she cooled off then she startwed hiccuping again. Tuesday afternoon, hardly made it home same deal until it warmed up. when i got home, i tried to restart her and she refused, hasnt started since. Has no spark and tach doesnt bounce when turned over. Am i correct in my assumption of the reference sensors. Thanks so much for your time and help, Josh |
Really dumb question on my part, but are you sure they afm/tps are plugged in?
I sent you a PM about the sensors. |
Jiggle / clean the connectors for the speed and reference sensor. Sometimes there are intermittent connection issues.
I cleaned the reference sensor AND bam, she fired right up, i drove her around and she drove great. I went home, turned her off, added some coolant AND NOW IT WONT ****ING START AGAIN, except this time the tach does move so its not the sensors.
Im going through everything again, |
your getting there! Could be a loose connection somewhere.
ive gone through everything, its getting spark, i havnt tested for fuel but im sure its getting it, ive cleaned and made sure every wire was connected. Its just refusing to start. ive check all the fuses tapped on all the relays.
There is no way to test the DME except to swap in one that is known to be good. I was in the same situation you were in 3 years ago. Replaced both sensors one by one, but the problem was still there. The only place left to check was the DME. I removed and resoldered it, and that fixed everything. My guess - you probably don't have an oscilloscope so I would recommend making sure the connectors at the sensors are clean first and test their resistance per Clark's Garage. If they pass, go ahead and check the wire continuity between the sensors and the connector at the DME. I don't remember which pins to test, however but the pinout may be available at Clark's Garage. Odds are this will be good too but you never know. You *may* be able to test the DME by knocking on it while you crank the engine and watch the tach to see if anything happens. If that does anything to bring even a glimmer of life to the tach needle you've found the culprit. Maybe someone around could loan you the part(s) to swap in something that's known to be good just to test things. I'd volunteer my old sensors but they're in questionable condition. If this was a year earlier I could've just gone over to check things out but I moved to Seattle from San Antonio. edit: you never know you have spark until you see it. The still tach needle makes me really skeptical... If you somehow have spark but no movement at the gauge it's pretty much certain that the DME is the culprit. They can easily be resoldered. |
i have spark and movement at tach though just no start,
Sent you a PM.
How do you know you have spark though? Did you use a spark tester or just assuming you do since the tach is bouncing? |
i pulled the plug and grounded it and had somebody turn the car over, i can see spark between the gap on the plug, josh
I'd vote for a vacuum leak. Something's loose when cold; when it warms up (and metal/plastic expands), the hole is sealed (at least partly) and it runs better. Spark or sensors wouldn't be affected by a hot/cold engine, Neither would fuel (except maybe the injectors). But vacuum leaks ARE affected by whether the engine is hot or cold... Backfires and what not are common as well, when you have a good vacuum leak. Just a thought. |
ok heres where ive gotten, i have movement at my needle, ive pulled the dme and when i turn the car over there is no movement at the needle and everything is exactly the same, but when its plugged back in the tach does move, So... my reference sensors are probably working seeing as the needle clearly moves which leaves me with the DME.
Im talking to a nice fellow on pelican forums who says he has a Known working DME from a 1987 924s, from what ive read it should be interchangable, correct me if im wrong on that one. so what im going to do is get this dme from somewhere and see if it makes her run. Thanks, Josh |
Sounds much like the problem I had with a huge vacuum leak on the underside of the intake manifold. Can you get it to start and run by feathering the throttle?
Speedy:) |
nope, refuses to run at all, i think the stumbling and stuff i described earlier was because one of the vaccuum lines coming from the air boot had come loose, when i drove it yesterday right before it refused to start it ran perfectly, just refuses to start now.
and ive had the refusal to start problem happen many times before and then it would just randomly start running again, so it has to be somthing on its last leg |
The DME was removed while you cranked the engine?
i pulled the dme and cranked the motor, the tach didnt move, when the dme is plugged in the techometer does move when i crank the motor so does this indicate that the dme is good?
no.
ive looked all over the forum, exactly why would the tach move if the dme was bad and not when its removed, is it just completing a circuit or is there a certain part of the dme that can go bad and cause the car not to start but still make the tach needle move. thanks josh
um, the DME is more complicated than simply registering that there is a signal from the reference sensor. it also has to pulse the injectors and the coil, among other things. if it was that simple, it would be computer as such, but could be a simple relay.
i am not saying that the DME is bad, just that this 'test' is not conclusive. i'd try a different DME. |
Well will a dme out of a 1987 924s work in my 87 with and 86 motor, thanks josh
Ok i have another interesting story for today, this bizzar ****ing car will really throw some **** at you.
I just for ****s and giggles go outside and try to start the 944, she starts right up, of course it randomly picks when it wants to run or not, ( It has done this before, many many times, and i knew it would happen ) Anyway, i start it up and turn it off and repeat about 5 times, then i take it around the block a few times, drives and runs perfect. I drive for about 30 minutes, stopping and restarting. Finally a little happy, still skeptical though cause i just know deep down its going to stop running again. I pull into the driveway and turn it off and on about 5 times, i let it idle and once the fan kicks on, the car stalls out, and now it wont start AGAIN. PIECE OF ****, is this car not bizzar, Josh |
My kid had the same exact sort of problems with his 951. It'd run good, then die and refuse to start. Over and over. and over.
It turned out to be a bad connection on the speed/ref sensors - where the cables from the sensors plugs into the harness to the DME. The wires had been handled too many times and the connection was intermittant. He solved it by cutting out that section of wire (on the DME harness) and splicing in new sections - and then soldering the connections. The car runs fine now. But it took him months to figure it out. |
I had a simillar problem, the sensor bracket was loose causing the sensor gap to go slightly out of adjustment, this took a few tows to figure out.......
I have seen 2 cases of very odd no start problems that is not related to the DME relay or sensors. One time, the short ground from the battery negative to the battery tray area was not bolted in. Another time, it was the injector harness shorting intermittently from melted insulation. You need 4 things for any car to start 1. compression (you have) 2. physical cam timing (you have) 3 properly timed spark (not sure) 4. fuel (not sure). When the car is not starting, shoot starting fluid into the intake and if it does not start, then you have mistimed spark from a bad DME or something electronic related. If it starts with starting fluid, check for injector pulse with a noid light (not with a volt meter - it won't work). Let me know what you find after starting fluid and noid light.
ill try that today
a dme from an '87 924S will work in your car. i am betting it is the sensors, however.
http://forums.pelicanparts.com/uploa...1202440910.jpg |
Put a Noid light on one of the injector terminals tomake sure they are firing.
Pull the distributor cap & check the rotor. It could be loose or if you have one with the black stuff between the coil terminal & plug terminal look for a pit. It could be the resistor, capcitor or whatever is in there blown out. I think it is susposed between ! & 1.5 K. |
relay
Just to clarify - have you tried swapping in a new, < $30, DME relay? Even if it doesn't change anything, it's good to have one.
My no-start issues were EXACTLY like yours and I wish I'd just bought the DME relay earlier... Good luck! |
If you don't have an oscilliscope handy, you can try the alternate test (thank SoCal for this idea - his legacy lives on!)
http://forums.pelicanparts.com/showthread.php?s=&threadid=343212&highlight=LED+se nsor |
Saga Continues
replaced both sensors with new ones and set for the timing, replaced the dme and she will start up and run fpr about 15mins perfectly and then shut off and wont start for an hour or so, i dont know what do do next
when it doesnt start, do you have spark? if you do:
install a gauge on the fule rail, when it doesnt start see what the fuel pressure reads |
Seriously, you've gotta test it out when the car won't run anymore. It almost sounds like something in the system is heating up... fuel pressure would be great to know when you turn the car on and again when it no loner runs. I don't remember if you verified whether or not the car has spark when it fails but that's worth double checking as well.
This sounds a lot like my '70 Ford truck acted when the fuel filters were clogged up. It'd start up just fine and let you drive off a few miles before the filter plugged up again and then it'd quit. Much later once the pressure in the fuel lines died down the debris in the filter would settle and you could go again until things got plugged up. |
has spark when it won't start, new fuel filter,as well
So it's got spark, assuming it's got air... fuel is the only culprit left.
fuel or the electronics involved with the injector. Try starting fluid and it should start right up. If it does not, then its not fuel.
If you have spark (assuming at all plugs)... forget about the reference sensors they are fine.
As has been mentioned. - check if the injectors are firing. If I was a betting man I would say you have corroded injector harness. Pretty common. |
An offer in case you read this - I'll be down in San Antonio in May, (perhaps April as well) and if you're having issues with the car I could come have a look at it sometime.
traded the car for a 71 vw super beetle compltely restored. I might get another 944 down the road, Thanks Josh
