Fuse Box
We have an 87 944 Turbo, have replaced the dme relay twice, now have it wedged next to the other relay to keep it functioning. How do we remove the fuse box to tighten or clean the contacts for the relays ? Thanks for any help. Bob
Bob
Old 10-16-2010, 06:59 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Disconnect the battery, then standing by the left side of the car look down into the fuse box, there is a thumb screw in the lower left and upper right corners. Remove these screws and carefully lift out the "plate" that holds the fuses/relays. you don't need to remove the whole fuse box, only the "plate" that holds the fuses/relays.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 10-16-2010, 08:30 AM
Thanks very much - hope this cures it for good. Bob
Bob
Old 10-16-2010, 08:55 AM
where are DME's located I have a 86 na....Thanks Frank
Old 10-16-2010, 11:56 AM
Burn the fire.
Brando's Avatar
DME is located in the passenger footwell. Be sure there are no leaks from the battery tray into that area. Water and DMEs do not mix well.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 10-16-2010, 12:54 PM
89-944NA's Avatar
under carpet, under wooden false floor passenger side
Semper Fi
Old 10-16-2010, 02:07 PM
