-   -   Wiring problem need help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/391496-wiring-problem-need-help.html)
ace_944 02-06-2008 09:41 PM
I was working on some of my wiring and saw this wire, I was gonna try and follow it back to see where it went and before i could it popped off whatever it was on. So if anyone knows what this is and where it goes it'll be a big help.
http://forums.pelicanparts.com/uploa...1202362401.jpg
http://forums.pelicanparts.com/uploa...1202362730.jpg
http://forums.pelicanparts.com/uploa...1202362774.jpg
Scuba Steve 02-06-2008 11:03 PM
What was it near? It doesn't look stock...
GostRidr 02-07-2008 01:00 AM
Year and model might help.
Amet_944 02-07-2008 05:09 AM
it looks like a thermostat(like the one you have in a fridge) to switch AC on and off http://forums.pelicanparts.com/support/smileys/wat5.gif
944 Ecology 02-07-2008 05:36 AM
Connector for oil level sensor.
ace_944 02-07-2008 06:54 AM
its a 87 944 n/a and it was on the same wiring harness as the oil pressure sender. All the wires on that last tail were melted.
924Sman 02-07-2008 08:13 AM
Passenger side, just above or at the top of the oil pan towards the rear portion(engine) apprx 1/2 way up from pan bottom. Triangular shaped plate with screws and the port the connector insert into. Once you see it you will know it goes there because the shape is unique.
Dal
JivenJim 02-07-2008 06:57 PM
Low Oil Warning light Plug. 924Sman has it.. It just slips back on like a spark pluge wire.
ace_944 02-07-2008 11:29 PM
Cool, got it all hooked back up. Thanks for all the help guys.
