Question low oil psi/ level cutoff?
i have a 84 944 that starts and stalls i have tried everything i can think of. i did clarks tests on afm,tps coolant sensor, o2, i replaced the coolant sensor and fuel psi regulator, cleaned all grounds i could find, checked for 12v @ injectors i was wondering if these cars have a low oil psi or level cutoff, the psi gauge reads plenty, but now im grasping at straws.
Old 02-08-2008, 04:18 AM
That Guy
Techno Duck's Avatar
No automatic cutout. There is only the pressure gauge and low level light.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-08-2008, 04:51 AM
earlr85944's Avatar
it starts and how long does it run for? Check the J-Boot for tears and air leaks.
Is the fuel freah and adequate? Hows the spark? Did this start all at once or slowly?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 02-11-2008, 12:20 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
There is a vacuum line that connects to the jboot right on the corner on the bottom that you cannot see...you can only feel it. Make sure it is in.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-12-2008, 01:37 PM
Eldorado's Avatar
see if you can keep it alive with the throttle.
if you can, it's more likely (as these guys have said) a vac leak.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 02-12-2008, 02:31 PM
the car sat for about 4 months. it was running before that. i put in fresh fuel. i also lifted the intake to check for vac leaks. i believe i have a bad dme. doesn't help its so cold outside. got fed up and dropped it at local porsche guy. i'll update on his findings. thanks for all your help.
Old 02-12-2008, 04:35 PM
