Big Brakes?
Hi again i have an 86 n/a and i was wondering what kind if any big brake packages there are for my car?
Thanks, Dave
1986 944 N/A
1972 GTO
1979 Trans am WS6
Old 02-13-2008, 05:26 PM
What do you need big brakes for? They just slow you down.
Good luck, George Beuselinck
Old 02-13-2008, 05:40 PM
That Guy
Techno Duck's Avatar
Rennbay makes a bolt on setup for the front only. Upside is you can retain 15'' wheels and do not need to swap spindles.
There is also the factory option available from the 951 / S2. You will need to change the front spindles however (in your case ones from an '86 turbo).
I upgraded using the 951 / S2 setup on my '87 n/a. More braking power than a 147bhp, 2700lb car would ever need. I favor the factory setup because it replaces both front and rear with 4-piston calipers and also the benefit of larger rotors (better heat capacity).
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-13-2008, 06:07 PM
Think that Wilwood has a brake upgarade
drew1
wife has 924 turbo
Old 02-13-2008, 06:26 PM
meister member
speedracing944's Avatar
another option is to go with Jaguar XKJ front brake calipers. They are huge 4 pot but are made of steel and not Aluminum. There is a write up about the upgrade on www.porschehybrids.com
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-14-2008, 03:32 AM
Non Compos Mentis
First step is to let us know what is inadequate about what you have- What are you trying to improve?
I race a 944 on completely stock brakes. With nothing more than fresh fluid and Porterfield pads, I can out-brake most others in my class.
First make sure your system is operating as it should.
If you want big brakes because they look cool, then just install whatever you think looks best.
Old 02-14-2008, 12:47 PM
