-   -   Did a Compression Test (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/393643-did-compression-test.html)
GreenWater 02-20-2008 10:30 AM
My cars oil pressure is always at 5 bar or higher while driving. Is that normal, or too high. It does drop to around 2 or 3 while at idle. It seems too high to me, but everything works good, and the oil level is correct. I am now curious again because tidybuoy was talking about his oil pressure being that high. Could my OPRV be stuck as well? And what problems can that cause?
Techno Duck 02-20-2008 10:33 AM
That is completley normal. Oil pressure will be at ~5 bar when the engine is cold and when higher than ~2.5k rpm. It should drop to 2-3 bar at idle on a warm engine. Nothing to worry about.
GreenWater 02-20-2008 10:43 AM
Okay, that makes me feel better. If the oil pressure was to stay at 5 bar while at idle, would that be from the OPRV not working right?
Razorback1980 02-20-2008 12:55 PM
Yes, OPRV would be one possible problem.
