West Central Ohio 45380
special lug nut size
I am in the process of taking off the lugs from the new car I picked up and each wheel has 4 19mm lugs and 1 larger lug that I can't seem to get anything to fit. I am sure it is there for security reasons but does anyone know what size socket/special tool I need to get them off? TIA
Trying to work for parts!
PO's can do funny things. It is even a lug nut or just a bolt?
Have you tried standard sockets?
86 Metallic Grey 85.5 Metallic graphite - Gone |
I have tried everything that I can think of except a 20 mm which I can't seem to find. The problem is that a regular socket is too thick and that I can't get it to the lug without hitting the outside of the rim hole? grrrrrr
Try a 13/16 socket
Always start with the cheapest option first 83 NA Guards Red ( Home at last) 2011 Triumph America |
yep 13/16 is a no go.
is it a wheel lock, like a special nut-head that requires a key? Is there one on each of the four wheels?
1983 Scirocco (RIP) 1983 911 SC (SOLD) 1987 NEUN44S #8 SCCA-NNJR 1999 Volvo XC 2000 Suburban |
The way I see it you have 3 options:
1) Look around the car and try to find the lock nut key( could be just a fitting to go over the lug nuts) 2) Try to find a socket/spanner to fit the lug. 3) Use a cold chisel to romve the lug nuts then go and get a new set and keep the key in the glove box. I prefer option 3
socket
Hey ply , I read this post before and I found that socket you need for that lugnut if you already havnt removed them.
I dont know how I have one but I found it going through some old parts. If you need it, just pay postage and return it to me. Thanks
07 Ranger Super Cabriolet Parting a 85.5 and 2 86 944's ..2 automatics, 1 5 spd 87 944 S 06 Harley Davidson Heritage Softail |
If the outside of the socket is too large and hits the wheel, then a grinder will fix that. I have had to do this before on something else I was working on. I had the right size socket but the outside was too big. I took a grinder to the outside of the socket until it fit.
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
socket
I have the factory Porsche socket. They do exist. He must have them off by now lol
