GreenWater's Avatar
dieseling problem
Can a vacuum leak cause the car to diesel when I turn it off?
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 02-24-2008, 12:02 AM
meister member
speedracing944's Avatar
My car dieseled when I had a huge vacuum leak under the intake manifold and it went away when I fixed the vacuum leak.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-24-2008, 06:42 AM
GreenWater's Avatar
That must be my problem, a vacuum leak. My car will diesel every once in a while and the idle jumps around when the car is cold or hot. I will check all my vacuum lines, thanks.
84 944
Old 02-24-2008, 09:57 AM
