altrernator wires
ok, is there a special way to remove the red wire?? BTW, idk if the photo i added worked.
No picture.
The wires should just bolt to the alternator. nothing special about them. |
Should be a 13mm nut, make sure you disconnect the battery unless its an early 4th of July celebration.
yeah, i'm replacing the whole starter harness and am a little tricked up on the the red one, because it has a little rubber boot on top. I'm thinking just pull till it comes off, but last time i did that i pulled alittle too hard =0.
| All times are GMT -8. The time now is 06:26 AM. |
