944S (87) Rear Shock Install Question
What is involved with swapping rear shocks on an '87 944S? Any special tools? Obviously lift and carefully secure the rear end with jack-stands, then loosen top, then bottom bolts. Is that it? What am I missing? Will the exhaust be in the way?
![]() Thanks in advance for feedback
1983 Scirocco (RIP) 1983 911 SC (SOLD) 1987 NEUN44S #8 SCCA-NNJR 1999 Volvo XC 2000 Suburban |
Trying to work for parts!
Bolt on top, bolt on bottom. 10 minutes later all done.
Having an impact wrench will help tremendously! this really is not that difficult of a job. On a scale of 1-10 (10 being the clutch of engine swap) I would put this at a .7
86 Metallic Grey 85.5 Metallic graphite - Gone |
Yep, pretty straight forward. you might run into problems breaking the bolts loose. just give it a good liquid wrench soak for a bit and you should be good to go.
That Guy
Very easy, no need for a lift..can be done on jackstands. Support the rear across the torsion tube using the jackstands. You will need a 22mm socket for the lower shock bolt and a 19mm for the top. You will probably have trouble breaking the bottom loose.. a good size breaker bar really helps. For the top, you will need to use an open end wrench on the inside to hold the nut while you loosen the bolt.
It will make things alot easier if you remove the preload on the suspension parts by lightly jacking up the trailing arm enough to square everything off... IE, eliminate some of the tension on the parts.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Thanks I thought so. One more question:
What are the upper/lower bolt torque settings? How many ft-lbs. to tighten?
guden tight! sorry couldn't resist..
That Guy
Lower Mount : 91 ft-lbs Top Mount : 45 ft-lbs
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 03-06-2008 at 09:03 AM.. |
Other way around; 45 top, 91 lower.
-- Jim 1983 944 |
That Guy
Whoops, Jim is correct. I have those reversed.
I just did this last weekend and found it as easy as stated above. Only hitch was that the upper eyes of the POS AC-Delco shocks I removed were narrower than the proper Koni replacements and the upper mounts had been squeezed together slightly. I spread the mounts with a small crowbar and the Konis slid right in place.
Terry 2016 Cayman 2004 R1150S |
Very technical german torque specs....my favorite.....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Prior to jacking up the trailing arms, use the jack uder the breaker bar to break the guden tight lower bolts loose. Saves on wd40!
Should be easy. My lower bolts defeated me, however. No luck with impact gun or breaker bar (car on stands). Gave up and brought it to my mechanic who also had some difficulty, but at least succeeded.
1995 993C4 guards red 1988 944S alpine white |
I used a short pipe on a 1/2" breaker bar on the lower and had no problem. My upper bolts were big trouble until I used a four-way lug wrench and both hands.
Mine was up on ramps instead of jack stands. When applying force to the lower bolts, the weight of the car kept the trailing arms from moving and they broke free witht he froce of the jack. I barely tried by hand and went to the jack for assistance, and they were guten tight!
Politically Incorrect
If I'm not mistaken, you have to pre-load the rear swing arms before final torque. Easy if you use two floor jacks.
Edek '87 924S '91 535i |
