Recreational User
Hello, all.
I've run into a guy selling a 1980 924 turbo. He claims that it's the Rest-Of-World version, i.e. 170hp version, but he really doesn't know much about Porsches. So... rather than drive 3 hours just to prove his claim, I asked him for the VIN. It's 93AO150498. Does anyone know if this is a ROW VIN or not? I can't seem to find any reliable info on the net. I did find one source - Original Porsche 924/944/968 - that shows this VIN as Japanese... but this source hasn't always been accurate for me. If anyone has anything to share, I'd appreciate it. Thanks.
'88 924S - Stone Grey Metallic |
I'd like to know this as well. Possibly the instrument panel cluster may be different (Speedometer KPH/MPH)... just guessing here.
2006 Porsche Cayman S 2006 Lotus Exige (Sold) 1986 Porsche 944 (Sold) 1981 Porsche 931 (Wrecked) 1987 Porsche 944 (Sold) |
Pretty sure that is a sign. ROW speedo should look like this....
You need the 924 VIN decoder!!!
http://www.924board.org/register/vindec.html Actually, I ran yours through, but it doesn't clearly indicate a model (US/UK/RoW etc). It's actually 93A0150498 (the first "O" is actually a zero), and I don't believe there's anything in that VIN to indicate... if anything, might be "450" instead of "150"... Perhaps a better way to confirm the EU origin might be the engine #, since he's trying to sell it as such he should be able to provide a good photo that clearly shows the Euro engine code. Best of luck!
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
Recreational User
mr. dude... do you know if the Japanese model would have kilometers or miles? I'm also trying to distinguish between ROW and Japanese since the Japanese had the same smog controls as the US.
924RACR... where do I locate the engine number and what should it read? It's been awhile since I owned a 924 and I'm sure this guy is gonna have trouble locating it.
not always. my RoW '80 turbo is a UK import with both miles and kms on the speedo.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
The engine code is stamped on a flange at the back of the engine, next to the bellhousing, by the timing window, and under the back of the intake.
Not easy to get to/photograph, but he can't expect to get the top dollar for a Euro engine if he can't prove it is one!!!
Thanks for clearing that up. I wasn't exactly sure.
What about carfax?
Dave 82 928 Weissach #14 |
Recreational User
Unfortunately, Carfax isn't available for these older VINs.
Thanks, all... for the suggestions and info.
I've also run Carfaxes on my cars (the 81-82's, first years Carfax even registers), had them come back clean.
The cars did not warrant it. They all have been hit, etc. Not that I'm so worried about it - just an FYI that a clean Carfax for such old cars, IMO, is meaningless.
According to http://www.connact.com/~kgross/FAQ/944faq02.html that is a US, Canadian or Japanese VIN with the 15 being the key:
The 924 Turbo (931) Model Year Market Engine Code Displacement (cc.) HP @ RPM (DIN) Stroke/bore (mm.) Compression ratio Management system Transmission Code Weight (lb.) Chassis numbers 1979-80 EU, RoW M31/01 1984 170 @ 5500 84.4 x 86.5 7.5 : 1 CIS K-Jetronic G31/01 2779 93 A0 14 0001 – 9999 1979-80 US, CN, JA M31/02 1984 150 @ 5500 84.4 x 86.5 7.5 : 1 CIS K-Jetronic G31/02 2779 93 A0 15 0001 – 9999 Apparently EU and RoW had VIN's starting in 14
Mark ![]() 1980 931 |
Loser.
1987 951 ROW |
uuuuhh what?
My name's Jeremy. Are you confusing me with someone else?
Whoa, scared me for a second...was going "What did I do?" Never even posted on 924.org, but then I read the other thread explaining the situation with a different Mark...whew!
