need help w/split second -autothourity
Does anyone out there have any experiance installing a Split Second air fuel controller. Instuctions are generic. I need to know the wire number/color for the AFM signal input and temp input for ECU . the idle signal wire from the TPS. I also need to know witch wires on the autothurity MAF are signal output, signal ground, and +12v.
What does the fuel controler look like??
| All times are GMT -8. The time now is 02:57 AM. |
