rear oil seal install
While in replacing my clutch I decided to remove the flywheel and replace the rear oil seal. Removed the old seal and installed a new one. While in the process of reassembling the clutch and bellhousing I noticed oil leaking from the rear seal area. I installed the seal flush with the block surface. Should the seal seat in farther and could this be the cause of the new seal leaking?
I appreciate any suggestions. |
Did you wipe it clean after you changed it?
02 996TT Stick Modded AKA Tubsey 08 Cayman S 6spd 49k Black/Terra-cotta 04 Gallardo Gated 6spd 19k Arctic Grigo/Nero Blue 14 BMW M5 6spd Stick 06 Cayenne S 🌝 miles 1982 928 S 5spd :-) |
Yes, I wiped it clean before installing the new seal.
I do think it's suppose to be recessed. I remember thinking you could almost put two seals in there. If you didn't seat it properly, it's probably crooked and it will not seal.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Thanks. I will disassemble and see if it will seat deeper. I don't remember the original being too deep, but I didn't try to go beyond flush with the housing so it may well be not completely seated.
Rich |
Hi Rich, let us know how you did get the seal to seat correctly please.
