Turbo exhaust on an N/A?
I was wondering, would a cat back exhaust designed for 944 turbo bolt onto my '83 N/A? if not, what modifications would be required?
Thanks, Tony |
Nope, won't fit. Flanges are different sizes and 3 bolt (NA) vs 4 bolt (turbo).
Good luck, George Beuselinck |
meister member
You could always cut open the muffler on your N/A exhaust, gut it, weld in straight pipe, and weld the muffler back together for a stock look but straight through design. That is what I did with mine.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Cut the flanges off, and use an expanded slip joint.
I plan to try this on my '83 once my LR exhaust gets here.
Jack 86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi 83 Porsche 944 - Still under re-construction. 08 Suzuki Boulevard M109R LE 02 Nissan Altima SE3.5 |
I really like the sound of the ANSA sport exhaust for turbo, but they don't make it for N/A. Let me know how the fitment works on your 83 Jack.
I called Lindsey Racing yesterday, I won't see my new exhaust til after the 1st. So, it'll take a bit before I do this swap.
