Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Tips for Removing Intake?
I am on step 24 of this headgasket procedure: http://members.rennlist.com/tom86951/headgasket.htm
It seems that "intake should pull up and out" is close to the Haynes' manual's "installation is the reverse of removal" hillarious oversimplification.
The intake seems as secure on the head as it did when the allen bolts were still attached. Any tips on getting it off?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-21-2008, 03:32 PM
That Guy
Techno Duck's Avatar
One 13mm bolt on front by throttle body, two allen head bolts by oil fill tube, one 10mm (or maybe 11mm) bolt holding the dip stick tube mount and the 8 allen heads. Also disconnect the speed / reference sensor bracket. Im pretty sure thats it.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-21-2008, 03:54 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
The 13mm bolt is easy to forget but it looks like the procedure addresses it on step #22.
The allen bolts at the rear (step #20) are also easy to forget.
Just go around and check everything slowly/carefully. Could just be a hose or getting hung up on something. One thing about a 951 is you'll get a LOT of experience pulling that intake off. I used to be able to do mine in about 15-20 minutes.
Check the back of the intake close to the firewall. There are a lot of wires, hoses, and other junk back there that the intake loves to get hung up on.
Black Cars Matter
Old 03-21-2008, 04:05 PM
Writer/Teacher
CJFusco's Avatar
I removed all aforementioned bolts, brackets, hoses. The thing still feels like it is bolted down to the head! It literally isn't even loose. I can't even wiggle it. It's on there like it's bolted down.
Old 03-21-2008, 04:21 PM
Professional Bull5hiter
Outback Porsche's Avatar
I just removed mine yesterday to get at the oil separator. I had to hit it with a rubber mallet to get it to break the seal on the gaskets.
Cheers,
Jeff
Jeff
83 944 Guards Red
23 718 GT Silver
Old 03-21-2008, 04:44 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
You got off all 8 alan bolts right?
Try hitting it from the side with a rubber mallet if you have.
86 Metallic Grey
85.5 Metallic graphite - Gone
light whack with a deablow hammer will probably break it loose.
86 944 NA 2.5
Old 03-21-2008, 04:45 PM
Writer/Teacher
CJFusco's Avatar
aha got it. the gaskets were stuck. got a screwdriver under and pried em up one by one.
Old 03-21-2008, 05:03 PM
Redline Racer
HondaDustR's Avatar
Without gouging the sealing surfaces I hope!
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-22-2008, 04:54 PM
Writer/Teacher
CJFusco's Avatar
Yup, I was very careful, don't worry. That's why it took me so long to get the intake off, I was being overly cautious.
Old 03-22-2008, 06:49 PM
