Politically Incorrect
Water pump stud removal - how?
Before I attempt to remove these studs, does anybody have advice on how to do this without breaking them off in the hole? I used a dental pick to clean all the gasket material away from the base of the studs and then squirted PB Blaster overnight, but they are not budging (with double nuts). Do I need to get my torch out to heat the area? Also, how hard do I actually need to hit them to "wake" them up?
Edek '87 924S '91 535i |
They usually have to be heated up to be removed. I install double nuts, and heat the area around the studs until they break loose.
Keith Belcher '87 951 nautic/cancan |
Learned by do'n twice
If possible, weld a big nut onto the bolt shaft. The combination of heat and the new leverage available with the new nut almost always breaks them free.
jmd_forest
86 944 NA - Brought back from the dead |
