rex00111's Avatar
Death by Porsche...slowly
Ok, so here is the run down....
Bought the car, it had been sitting for three years...
Pertinant information....
1. The horn beeped every time the door opened when I went to trailer it home
2. It starts in starter fluid, or did then, but it has yet to run on gas
3.Replaced
Fuel Pump
Fuel Filter
Fuel Damper
Fuel Pressure Reg.
All Vac hose
Battery
Ignition coil
Spark plugs
Plug Wires
DME
ALL small fuses
Headlamp relay
J-boot
---- cleaned all fuel lines, jumpered the pump, all is well.
so then I...
-----Tested for spark, no spark
-----jumpered the alarm, no help
The horn will sound when I go to crank the car, but not every time, and that is a new development, really only happened when I went to try to crank it, and the battery had started to lose power. I have a trickle charger on the battery that I plug it into to keep it charged. I do have a factory alarm, but my ignition key does not fully fit it...however I can turn the keyhole cylinder??? Shoul dit be vertical? Horizintal? HELP!!!!
There is no spark that I can see.....have not tested the injectors
What do I do next??? Thank you all for your continued help. What do you think, is this an electrical issue related to the alarm????
I just really don't want to have to pay a 100 dollar an hour mechanic, and the tow, and the yadda yadda, when I should be able to do this on my own, and use that money to buy things the car needs.
1986 944 n/a
1988 924S
2001 Navigator V8 Guzzler
Old 04-01-2009, 02:13 PM
rex00111's Avatar
Forgot to list replaced dist cap, and rotor, and belts......
1986 944 n/a
1988 924S
Old 04-01-2009, 02:20 PM
so if it ran on starter fluid, then u just need to check fuel again. if u have pressure at rail, and injectors actually fire.
Old 04-01-2009, 02:26 PM
Feelin' Solexy
Tishabet's Avatar
You must have spark if it runs on starting fluid... unless it only ran that way before you did all the work?? How are you testing for spark? Are you sure the coil is hot?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 04-01-2009, 02:53 PM
75ohm's Avatar
How old is the gas in that tank?
www.rennwish.org
'88 944 NA - Red/Black with more tinkering done than probably needed.
Old 04-01-2009, 03:06 PM
rex00111's Avatar
fuel is fresh, it has cleaner in it, but that is all......and there is pressure at the rail
1986 944 n/a
1988 924S
Old 04-01-2009, 03:34 PM
Your injectors are clogged from stale fuel. It happened to my car as it sat for a long time before i got it. Pop them off, and soak them in carb or brake cleaner. Take the o-rings off before you do, as they will swell. Maybe before you pull the injectors, check for noid. They sell a light up tool that you plug into the injector harness, and it will flash a light everytime the computer commands the injector tofire. If it runns on starting fluid, and you have pressure, its a problem with the delivery
Old 04-01-2009, 03:43 PM
75ohm's Avatar
+1 on the injectors... pull them and what you can do is use carb cleaner and pulse them with a 9v battery...
www.rennwish.org
Old 04-01-2009, 03:48 PM
rex00111's Avatar
thats a new one on me, pulse with a 9v battery, can you PM the specifics on how to do that?
1986 944 n/a
1988 924S
Old 04-01-2009, 03:55 PM
75ohm's Avatar
Sure... wire up a 9v battery and touch the metal connectors on the injector where the harness plugs in. You can squirt some carb cleaner in the injector, let it soak for a minute holding it up right, then pulse the injector by holding one wire on the connector and brushing the other. You will hear a click each time you pulse it. I do it about about 5 times for 5 clicks, dump the carb cleaner out, and go from there. Hasn't failed me yet.
www.rennwish.org
Old 04-01-2009, 04:02 PM
rex00111's Avatar
Thanks, great tip.
As for the no spark? any ideas???
1986 944 n/a
1988 924S
Old 04-01-2009, 04:11 PM
75ohm's Avatar
Have you been introduced to clark's garage yet?
www.clarks-garage.com
Check the garage shop manual...
No spark is dme relay, dme, coil, cap, rotor, injector wires, injectors, plugs.
Pull the the wire off the last injector, closest to the fire wall, and start the car.
If it starts but stumbles, bad FPR.
www.rennwish.org
Old 04-01-2009, 04:16 PM
rex00111's Avatar
tested for spark by pulling the plug, and grounding on the intake......and yes it started on starter fluid before all the work, about a month ago.
1986 944 n/a
1988 924S
Old 04-01-2009, 04:17 PM
75ohm's Avatar
Uh oh... you replaced all the vac lines???
Check the main vac line running from the brake booster to under the intake manifold below and behind the throttle body... I routinely forget to put that bastard back on and it causes me all sorts of grief.
www.rennwish.org
75ohm's Avatar
And another thought... plug wire order on cap.
www.rennwish.org
Old 04-01-2009, 04:18 PM
Proprietoristicly Refined
John_AZ's Avatar
You could also follow the instructions from Pelican Tech Section above^^
http://www.pelicanparts.com/techarticles/944_fuel_injector_clean/944_fuel_injector_clean.htm
Here is info on da noid light:
http://www.noidlight.com/
You do not have to get a noid light kit. One will do-Bosch P.F.I. (port fuel injection).
GL
John_AZ
1988 924S + 1987 924S
Old 04-01-2009, 04:25 PM
rex00111's Avatar
I have put on a new FPR, All the vac lines are tight...so that has been covered,
Plug wire order is
4 2
ign
3 1
as for clark's that website has helped a ton, but still trying to working out this no-start no sprak issue
1986 944 n/a
1988 924S
Old 04-01-2009, 04:36 PM
Question No Spark--Horn sounds?
Sounds like you have done all the right things so far. Just a thought---this may be related to the alarm. Try disconnecting the alarm wires at the horns.
Old 04-01-2009, 05:26 PM
TibetanT's Avatar
If your car came with the factory alarm and you say the horn goes off when you open the door, then your factory alarm works and is "armed." Which means it will not let your car start.
One thing that comes to mind is the switch located near the fuse box attached to the frame of the car. Make sure that switch is tight, so it doesn't fall out when you close the engine hood. If that switch falls out when you close the hood, then the alarm will also be armed and not allow the car to start.
To fix, or test your factory alarm:
1) close the driver's door
2) turn the key/alarm vertical
3) open the driver's door or the engine hood
IF the loud horn goes off, THEN your factory alarm is working properly.
Hope this helps. (You may have to try setting the alarm on and off a couple times until you know which key position is correct.)
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-01-2009, 06:36 PM
xupkid2's Avatar
2 thoughts. There is a bypass for the alarm to test if that the is the problem. Clarks Garage has a write up on it. If that doesnt work and the injectors are clearn test the DME relay by bypassing it. Again Clarks Garage has a write up on how to do that.
1989 944 Turbo Cup Replica
PCA Space Coast Region #44
Old 04-01-2009, 07:26 PM
