Shifter Fix !!!!!!!!
When I bought my car the shifter was very limp (It needed some Viagra for shifters
I decided to pickup a new shifter from Pelican Parts
The shifter installed...hmm not very happy with the outcome
It was better, but not great. I thought about buying a Short Shifter, but I just bought the new OEM shifter. I started to study the shifter, and realized the problem is with the rod that goes back to the Transmission. It has not guide to keep it from floating around...?
Today I installed a new shifter boot from Rennbay...very nice quality !!!
So what did I do ?
This is what I did and may not be for everyone
I started with some black (color does not matter of course) Duct tape.
I wrapped the fitting on the lower shifter with tape as tight as I could get it...this keeps all the movement from the shaft and clamp intact. I know another method is using a bolt and thread, but the tape works awesome. Next I took some lubricate and shot some out the door of the car to get a nice clean stream, then tipped the can and shot it right down the shaft toward the transmission (make sure you have a sprayer with a fine stream,not spray or use the red extention tube) next I took some garden hose and slit it all the way down about 4 inches of it. and I slid it on the shaft and forced it through the foam that houses the shifter shaft, I wrapped some duct tape around that as well and made sure everything was tight, last thing I need is to not be able to hit a gear Put everything back together and wow, what a difference, feels like brandnew.
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 04-04-2008, 01:58 PM
Eldorado's Avatar
LOL
why do i sense "you'll NEVER guess what the PO did to my car!!!" at some point in the future when you sell it =P
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-04-2008, 03:13 PM
rporzio's Avatar
You did what?
RPorzio
84 944
Old 04-04-2008, 03:16 PM
Originally Posted by rporzio View Post
You did what?
Yup, you read correctly. Duct tape and garden hose.
1986 951 Sold
Old 04-04-2008, 03:19 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Now you understand why your questioning why the door is painted a different color huh?
Garden hose & duct tape. That's a new one.
Bet if you would of replaced the pastic bushing it would of been a huge improvement and you wouldn't of had to go through that.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-04-2008, 05:51 PM
Redline Racer
HondaDustR's Avatar
Hey, if you can't see it, it works, and it's cheap....
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 04-04-2008, 06:47 PM
LOL... some of the things Porsche did from the factory are worse
Old 04-04-2008, 07:16 PM
Aslet's Avatar
It won't last you another 20 years, but I'm sure duct tape will be around when you need to fix it again.
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 04-04-2008, 07:41 PM
OnTheRun2's Avatar
Wile you were in there did you check your sock tension?
(Mae) Red '86 944na- gettting new paint soon.
(Abby) Black '86 944na- new addition to the family.
Old 04-04-2008, 10:20 PM
Eldorado's Avatar
and did you replace your lamp cords?
Kyle
Old 04-04-2008, 11:41 PM
I didn't think lamp cords had a limited life?!? I know that socks are only good for 15-20K miles.. But lamp cords....... I've never replaced mine.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 04-05-2008, 05:39 AM
It won't last another 2 years, but it is a nice tight fix for now. I am going to have the entire setup rebuilt the way I want it...tight. Just add it to the list
Old 04-05-2008, 08:31 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
Do tube socks tension better than low cut ones? And does color/pattern matter? I was thinking a nice argyle pattern to add some flare but I didn't know if they would affect how my car idles....I'm an ass.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 04-05-2008, 09:51 PM
944Spec_bound's Avatar
respect, though, for thinking out of the box. I think there's a little MacGuyver in all of us.
I've "field engineered" solutions to more than a few problems, some lasted a few hours, some several years.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 04-05-2008, 10:47 PM
TNT25169's Avatar
I wasn't trying to speak ill of a new idea, I just love a socks comment any time I can fit it in....hope all works out well with the shifter and if it does last, maybe it's something new for the 944 community....
www.apartabove.com
Old 04-05-2008, 11:39 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
yeah, i just had a bolt welded, then ground down the head, and cut the end to fit. wavy washer, and a little threadlocker, and i'm money.
i suppose garden hose and..er..duct tape would be alright as well :-D
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 04-06-2008, 08:10 AM
