blocked reverse?
when trying to put into reverse it feels like it blocked off
when running it grids, and when parked i go from 4th to reverse it feels like it's 1/2 way in. any clue what it is? or any easy fixxes?
dolor et pavor Copyright |
Could be a worn out shift lever. Reverse is usually the first gear to give trouble. If you have alot of play in the lever when it's in gear (any gear), that's probably your problem.
Dan Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc. |
feew.. i thought it might be something more serious. =)
