Question putting air in spare
probably a stupid question; but if you inflate the spare will it still fit in its tray?
84 944 n/a
Why tiptoe through life just to arrive safely at death?
Old 03-25-2008, 05:04 PM
Aufenbahn's Avatar
Umm, No - thats why its deflated. You should have a small electric air compressor in your storage compartment
Andy D.
Currently driving 2005 Audi A4
Currently driving 2006 Ram 1500 sometimes
Old 03-25-2008, 05:26 PM
Send a message via Yahoo to 1st84-944
Spin Off Question
No pun intended. If you inflate and use the spare, can you then deflate it and get in to fold back down and fit in its housing?
Old 03-27-2008, 06:24 AM
Let's go shooting.
Dark Skies's Avatar
I've never quite trusted those collapsable thingies. There was one in my wife's 944. We ditched it and bought the traditional steel wheel. You can keep that inflated - providing you get the rear carpet with the bigger hump.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 03-27-2008, 06:46 AM
Custom User Title
Dave L's Avatar
I dont know that I would even trust the spare tire at this point. They are now 20+ years old in most cases. Has anyone successfully used their spare??
Old 03-27-2008, 02:48 PM
Let's go shooting.
Dark Skies's Avatar
My wife used both hers and my spares on the front quite recently (three weeks back) - so she could legally drive to the shop to buy a set of tyres. Surprisingly both are in great shape with no cracking or signs of deterioration. I guess it must be because they're safely tucked out of the way of adverse temperature and UV rays.
Old 03-28-2008, 07:12 AM
Custom User Title
Dave L's Avatar
good to know dark skies, thanks
Old 03-28-2008, 07:19 AM
Schumi's Avatar
I once fully inflated mine to check to see if it would hold air. It did just fine and was in very good condition. unfortunately after deflating it, the tire never got back to as small as it used to be so it pushes on the carpet in the rear a bit.
I need to get myself a new compressor- like most people, the original did not come with the car...
M
Old 03-29-2008, 11:54 PM
AKCJ's Avatar
After I first got my car I went about checking the air pressure in all 5 tires. I thought the spare was flat so started to put air in. When it started to unfold I checked it out a bit and only then realized it was supposed to be a flat spare. I felt pretty dumb but then I think it's a pretty dumb idea too.
Red 83 944
Old 03-31-2008, 05:57 PM
Redline Racer
HondaDustR's Avatar
You kind of have to sit on it, or something like that, while holding the valve open and then releasing the valve before the tire. That worked for mine.
BTW, I drove on my collapsible spare for several hundred miles without any trouble, other than it handled like crap, especially in the wet! Actually it was quite scarry in the wet going around off ramps and such.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-31-2008, 07:49 PM
In the Fires of Hell.....
kdjones2000's Avatar
I had a rear get a sidewall shear flat on my way to work one day. Used my spare with a bicycle pump. Drove the car over to get a new set on the rear with no problems at all.
Took the air out of it and it went back to its original shape with no issues.
Cheers,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-01-2008, 12:58 PM
