931 transmission drain/fill plug question
Are they both 17mm? I have had the car long enough to change but I do not have a hex large enough to fit.
Yep.
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
I went to lowe's and got a bolt with a 17mm head then some nuts that fit on it and threaded several nuts on and welded them and used it as a large allen...much cheaper. Also the plugs can be a b***h, tap with a hammer lots and use lots of pressure. If the end up rounding off get a good welder. My dad welded the bolt into the plug since mine was rounded off before I got it. Good luck!
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
Note also that you can replace these pretty inexpensively, they should be around $5 new IIRC and Pelican probably has them.
