hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Fuel Pressure too HIGH!! More suggestions??
OK,
Having a fuel pressure problem with my 86 Porsche 944 N/A. I ahve seen that I need around 32 for a PSI. I installed one of those kist from Lindsey racing to installe the Fuel Pressure gauge on the end of the rail. My fuel pressure is reading around 42 PSI.
1. Installed a NEW FPR about 2 months ago, even installed my old one to check the pressure, it read 42 as well, so installed the NEW one back on.
2. Installed a NEW Vacc kit from Lindsey racing.
3. Installed NEW Rotor, Cap, MSD Coil, Lindsey Plug Wires and Bosch Plugs.
Bleed off seams to be normal, about 2 or more hours for the fuel pressure to go from 42-0 psi.
Suggestions on what to check now? Thanks Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 04-07-2008, 05:14 PM
earlr85944's Avatar
can you post a part number for the fuel pump
also check for a restriction in the return line by disconnectiong it and route the fuel to a bottle
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 04-07-2008, 07:14 PM
