Professional Bull5hiter
Outback Porsche's Avatar
Belt Tension Tool
Has anyone seen/used/verified this tool?
http://cgi.ebay.com/ebaymotors/Timing-belt-tension-Tool-Porsche-944-928-924-VW-Audi_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el124 7QQcategoryZ43998QQihZ008QQitemZ180228555702QQrdZ1 QQsspagenameZWD1V#ebayphotohosting
Jeff
83 944 Guards Red
23 718 GT Silver
Old 04-10-2008, 01:37 AM
meister member
speedracing944's Avatar
Somebody else posting this tool. Nope never seen it or used it. The 2 options I vote for are...
1) the P9201
2) Bruce Arnns P920X from Arnnworks
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-10-2008, 07:00 AM
+1 on the 9201... the only tool I would ever use. You have to have confidence in your adjustments at 6000 rpm...
Good luck, George Beuselinck
Old 04-10-2008, 08:00 AM
Jeff A.
Send a message via Skype™ to jbaeng
I'm looking for this tool as well for my '88 944 and wondering what alternatives to the Porsche tool are available. i know the '88 w/ tensioner make this tool not needed for the timing belt but it seams required for the balance belt? anyhow, here is a link to the Arnn tool:
http://www.arnnworx.com/new_tensioning_tool.htm
Also,I put the flywheel at the TDC mark and found the camshaft pulley about a tooth off, here is a picture of it:
I just bought the car ($1000) and towed it home for my new project, it's a mess but has a straight body.The balance belt was off and torn. When I bought it a few weeks ago I asked the PO when the cam belt was last replaced and her response was; huh, what's that? (the car has 170k miles so i did not run the engine anymore) once i got the cover off, the cam belt looks ready to break as well! The car started and ran but the water pump is shot so i towed it home. I'm going through the car now, getting it back on the road. i'll post other unrelated questions in a new thread.
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 04-10-2008, 08:58 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Someone else asked about that too. I personally wouldn't use it. Go with Bruce's tool or have a shop do it to make sure.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-10-2008, 09:19 AM
Nobody Special
I'm willing to give it a try but only after checking it against a properly tensioned belt. Harbor Freight sells the same gauge for $10 less. I've used the Kriket and don't like it that much especially when the air temps are low. I've got the 90 deg. twist down pretty good but another tool is always welcome. IMO people put way too much fear into tensioning these belts...it's a T-belt just like any other car and the same common sense and feel applies. Using the 'magic' 9201 tool is fine if you own or borrow one but it's another example of German over engineering.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 04-10-2008, 10:22 AM
Redline Racer
HondaDustR's Avatar
Borrow the P9201 once or twice and learn what the correct tension feels like, and just do it by hand after that (unless maybe it's some race prepped engine that you spent $$$$ on and want to be wicked sure it's right). It's even easier to learn it if you have the spring tensioner, since it will always get it fairly close for you.
I've been through two timing belts with several projects along the way requiring removal/reinstallation of the T-belt, and have not had any problems. ...and I'm a 6500 rpm addict!
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 04-10-2008, 05:52 PM
