-   -   replacing transmission input shaft (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/403097-replacing-transmission-input-shaft.html)
rusbear 04-10-2008 09:11 AM
I happen to have a new 944 late models tansmission input shaft, but there is no part number stamped on it, except for some color marks... so would be nice to know if anyone can identify its type or if there is a way to say for sure what differences are between S, S2, Turbo and Turbo S input shafts (regular 944 transmissions are excluded).
I know that S2 and Turbo/S trannys have the same type of stronger input shafts. So, if the one I have is S2 or Turbo/S than everything is great. I need to replace the old one in my S2 A0S transmission and want to make sure it's not from 944S models which is AGP/AGR type transmission or any other weaker type.
I'll be posting pictures of the rebuild as the work progresses...
