-   -   Crash Sensor and Airbag Light (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/403324-crash-sensor-airbag-light.html)
rj_verrilli 04-11-2008 01:04 PM
My Alert light is on as is my airbag light. The code says my left crash sensor is bad. I've searched the threads and parts list but can't find a clean answer for:
1. Is what I described a real possibility?
2. Where are the crash sensors
3. I've looked on Pelican Parts but can't seem to find a part of this type in the catalog so how do I buy one?
4. How does it get replaced.
Any help is appreciated. If you could email me at ralph.verrilli@vistagy.com I would appreciate it as I don't get to this forum often.
Thanks for the help.
- Ralph
#391 04-12-2008 10:15 AM
The sensors are located way up under the ends of the dash by the firewall. They look like this: Driver's side:
http://forums.pelicanparts.com/uploa...1208020367.jpg
Passenger side to the right of the altitude sensor (can't really see it but it's there with the yellow and black wire going to it):
http://forums.pelicanparts.com/uploa...1208020391.jpg
Look for the funky bolt heads, those are on all the airbag components.
944 Ecology 04-12-2008 10:17 AM
Note: The nuts mounting the sensors to the studs can be removed with a special socket. I got mine at Baum Tools, I believe.
