Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Talk to me about boost gauges
Considering that it's probably my addiction to booOOOST that got me a blown head gasket in the first place, I think it's probably a good idea for me to install a dedicated boost gauge.
I am new to the world of gauges, though. I want something simple (not flashy), as close to my stock VDO gauges as possible. I don't want anything flashy for the mounting hardware either - I'm not trying to impress anyone with my boost gauge, I just want to keep an eye on how much pressure I am getting. I might just run the line into the glovebox and look at the boost gauge when I want.
The key is, my interior is really nice, and I like it how it is (although I may update the steering wheel). What are my options?
Also, as I understand it, installing a boost gauge is as easy as cutting the vaccuum line at the KLR box and splicing in a "T' connector, right?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 04-11-2008, 08:16 AM
Turbo 13b guy
JayG's Avatar
I have a black autometer mechanical 30-0-20 boost gauge with the orange needle in place of where my clock was. No attention gets drawn to it and even at night it blends perfectly.
1975 911S Targa(333 hp/276 tq)
Old 04-11-2008, 08:45 AM
Well, if you want to match the VDO gauges, get a VDO gauge
I don't know how good the 'in the glovebox' mount will work out. I originally had my boost and A/F gauge under the stereo, and it really is a problem due to the fact you have to pull your eyes off the road to monitor them. I went for a dual gauge pod(Lindsey) for my gauges, and can monitor them more accurately.
I've seen where members either here, or on Rennlist made an adapter plate that allows the gauge to be mounted to the steering column, and have Mickey Mouse ears on it to allow the gauge to be placed up in the cluster area, this might be a good alternative to you. Or you can go with a single gauge pod mount, JC Whitney, modify it to fit, and heat it up to achieve the proper shape. Mount it low on the A-pillar and call that good.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 04-11-2008, 08:46 AM
Writer/Teacher
CJFusco's Avatar
Thanks for the ideas. I think I may go with that single gauge pod, although I would rather buy something with a built-in exact fit; unfortunately it looks like Lindsey only sells 2- or 3-gauge pods. I'll have to mull this one over tonight while I'm tinkering in the garage.
Old 04-11-2008, 01:04 PM
Writer/Teacher
CJFusco's Avatar
I kinda like the Lindsey 2-gauge A-pillar pods; you can get a package deal that includes the pod, a boost gauge, and an air/fuel mix gauge.
To where does the A/F gauge connect? How difficult is installation?
Old 04-11-2008, 02:07 PM
A/F gauge connects to the DME wiring. http://www.lindseyracing.com/IAFM-1%20Wiring%20at%20DME.rtf
My only real complaint about the Lindsey pod is that the gauges aren't aimed at you, they are basically aimed at your left shoulder. But I guess that's a minimal complaint. The quality of the pod is pretty good, though it could stand to be glossy. They are both at a pretty good level, and as I mentioned earlier, reading the gauges doesn't take any effort or distract from watching the road.
Jack
Old 04-11-2008, 06:13 PM
For a look that doesn't stick out, you'd probably want the Z-series gauges, 2614 and 2675.
I'm running the sport comp ultra lights, which are silver with black writing and red needles........ Stick out like a sore thumb, and don't match anything. I just happen to have them from my old car which they looked great in, as the main gauges matched these.
I've thought about selling these and going for maybe the Z-series myself, to make it look better.
Jack
Old 04-11-2008, 06:23 PM
Writer/Teacher
CJFusco's Avatar
Hmm I'm starting to lean toward Lindsey's gauge cluster, which mounts under the radio. I don't really need a 2nd gauge, so I can get the one-gauge cut-out and a boost gauge for pretty cheap (about $85). This way I don't have that ricey-looking A-pillar gauge...
still somewhat undecided, though.
Old 04-11-2008, 07:32 PM
That Guy
Techno Duck's Avatar
Dont get a cheapo a/f gauge that runs off the narrow band O2 sensor. Get a proper wideband. Just about the only thing a narrowband is good for is annoying you with flashing lights.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-11-2008, 08:38 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
I have the stock looking VDO gauge and innovate wideband XD-16 in the LR gauge pod. I think its about as stock look as it can get.
[IMG][/IMG]
Keith
1986 Porsche 951
Old 04-12-2008, 06:10 PM
