Trying to work for parts!
Send a message via Yahoo to hpservertech
Steering column removal
Who has done it? Any suggestions or tips?
Already have the steering shaft removed in the engine compartment.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-10-2008, 05:36 PM
Yep, remove steering wheel and switches, remove instruments, remove dash, grind off shear bolts attaching column to chassis, pull column out of the firewall.
Good luck, George Beuselinck
Old 04-11-2008, 04:49 AM
That's what it looked like. Down to just the sheer bolts now. Looked pretty straight forward.
thanks Geroge
86 Metallic Grey
Old 04-11-2008, 09:09 AM
Can it be removed with the dash in the car or does the dash have to come out?
86 Metallic Grey
Old 04-12-2008, 12:23 PM
I don't see how you can get to it with the dash in the car. At least, on 100 cars or so, I haven't been able to do it.
Old 04-12-2008, 01:52 PM
That's what I figured. Have the dash ready to come out.
For removing the dash, clarks calls for removing the sunvisors. Is this really necessary or can I skip that step?
86 Metallic Grey
Old 04-12-2008, 01:55 PM
I would like to see it done without removing the sunvisors... if you can figure it out, you're much smarter than I.
Old 04-12-2008, 02:10 PM
Got it out. I just loosened the screws for the sun visors.
All cleaned up and ready for the new dash to go in.
86 Metallic Grey
Old 04-12-2008, 03:51 PM
You're smarter than I am.
Old 04-12-2008, 05:00 PM
No, I dont think so. Just used to being able to bend some things from lots of speaker/radio installs.
86 Metallic Grey
Old 04-12-2008, 05:05 PM
