temp II question
hello i have a question and was wondering if any one knows the the value for the diode that is in the wiring bundle at the tempII sensor connector if you expose a lil bit of thewire there is a diode that is soldered in line if any body kow the uF or microfared of this diode plaes let me know
944 lover |
Not sure what you are talking about. A Picture would be great. Diodes are not measured in Farads. That's Caps. Most temp sensors use a Variable resistor (Varistor). Diodes are usually rated in Break down voltage.
| All times are GMT -8. The time now is 11:21 PM. |
