Potential new owner in need of advice
Hello and thanks in advance to all. A 1983 944 with 45,000 miles caught my eye and I'm going to look at the car today. Years ago I looked at buying one, but didn't pull the trigger.
Beyond ordinary used car stuff, is there anything in particular that I should be looking at? Any questions that I need to be asking about this particular car.
Thanks again.
Old 03-31-2008, 04:56 AM
45,000 miles? is it really 45..or 145...even 245...
Very low miles for a 25 year old car.
I'm a new owner so am no expert. I would listen for supercharger type whining when the engine is running...that would be a sign of bad bearings on a pulley in the timing belt.
The timing belt is something critical to the car. You need to know when it was last replaced or serviced (otherwise you'd be safe to do it as soon as you get the car).
Check the body for rust. The 944 is galvanized so should have anything much if at all...only the battery tray area could have much rust since it's not galvanized.
I understand that automatic cars have a damper plate in the transmission that has a limited lifespan and is spendy to replace...if it's automatic you might want to ask about that. Also listen for any noticable noise coming from the transmission when you're driving (the transmission is behind you on a 944).
I'm sure others will have better info than this.
Good luck.
Pete
"I Am The Stig!"
MistahSinclair
1986 N/A Daily Driving Project!
Old 03-31-2008, 05:53 AM
Pete - thanks for the advice. I'm told it is 45K original.
The car has phone dial wheels - I'm wondering if those are original.
Old 03-31-2008, 05:55 AM
Paul_Heery's Avatar
Two places to go for Buyer's Guide information:
Clark's Garage
http://clarks-garage.com/purchase.htm
944 FAQ
http://www.connact.com/~kgross/FAQ/944faq05.html
A lot of the information is redundant, but together they cover most areas for concern
Old 03-31-2008, 06:16 AM
Proprietoristicly Refined
John_AZ's Avatar
Here is a recent post and some suggestions:
Trying to decide
If the mileage is correct, be aware that all rubber, seals, clutch disk if manual, master cyl and on and on will need replacing. The water pump may be original and PLEASE do the belts the minute you tow the car home-unless the owner can show you the repair was done yesterday!
Expect to spend a minimum of $2000 the first year for new stuff (tires, shocks, repair...)not counting labor.
Welcome and good luck.
John_AZ
Old 03-31-2008, 06:25 AM
Misunderstood User
Phone dials were not available in 83. There were (2) choices:
Stock wheels 15" Cast alloy wheels (fuch looking)
Optional 7jx15 F and 8jx15r forged alloy wheels (cookie cutter)
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 03-31-2008, 07:15 AM
Excellent information. Thank you.
Old 03-31-2008, 10:05 AM
rickharrison's Avatar
As stated...maintenance records will prove its true worth...if well documented from new perhaps it is a true low mile car.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 03-31-2008, 10:51 AM
White and Nerdy
Tervuren's Avatar
Cookie's where forged? I didn't know that. I believe the Cookie Cutters to be cast, and the standard wheels, with Fuch's being optional. 15" x 7"'s all round.
As mentioned, these cars have only five digit odometers, and the actual mileage
could be 145,000, 245,000. If you have a consistent trail of maintenance records - odds are it accurate. My '84 944 is 69K, with most records from '84 up to present(its a big stack).
Most rubber parts, if not already replaced, will rot and lose effectiveness. If it hasn't been actively driven/maintained, seals, belts, etc, will need replacement. Always expect $2K in costs after buying as there are chances to find things the owner themselves don't know about.
If you have a Porsche shop nearby, have it taken there and a pre purchase inspection done.
Shadilay.
Old 03-31-2008, 02:05 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I would definitely recommend a PPI as Tervuren mentioned. It may cost a little but it just might save you a lot.
IMHO, the biggest things to consider are:
a) is this my only form of transportation? I know it's low miles and that makes it sound attractive but reality is it's a very old car and things are going to break. The second part to that statement is that parts are not available at your local auto parts (or possibly not even at the Porsche dealer) when you need them. Most things you will need have to ordered from a remote vendor like Pelican here. Can your car be down while waiting for them to arrive?
b) Parts are more expensive than normal car parts. For example a water pump will be between one and two hundred dollars for this car with a hundred dollar core charge...for a GM Monte Carlo...18 bucks. Are you ready to pay for all that?
c) Can you fix your own car? If you can't turn a wrench...don't even think about it! As already mentioned, the car is old and things are going to break. Not just any garage can work on a Porsche so finding someone who knows what they are doing and be someone you can trust is sometimes difficult. If you live in the Arkansas mountains...impossible. Take that into consideration when evaluating whether the car is right for you or not. There are a few exclusive tools for this car that are expensive like the belt tensioning tool...not all garages will have those tools.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-31-2008, 02:08 PM
I live in Kansas City, Missouri and there is a new Porsche dealer and several fairly highly regarded Porsche shops in the area. I couldn't agree more - a pre-inspection is really a must if my initial inspection pans out.
As far as turning wrenches - my hobby over the years has been restoring motorcycles (Harleys and two-stroke Yamaha and Suzuki road bikes). While I'm an absolute amateur I can usually get the job done.
This car won't get driven that much - if it is really nice (that's what I'm expecting) , the goal will be to keep it that way. It will be a hobby purchase.
I'm leaving in about an hour to go see the car.
Thanks again.
Old 03-31-2008, 02:38 PM
What a POS! If that car had 45K "original" miles then I'm 14 years old. "minor wear" - I guess he missed the 8 inch tear in the drivers seat. The pictures didn't show it, but the paint that wasn't faded was scratched or crazed. And I looked at the car at dusk - I can't imagine what sunlight would show. "Excellent condition" He has obviously rejected reality and substituted his own.
Thanks again for the info and I'll keep looking.
Old 03-31-2008, 06:38 PM
Here is the car - from better days I suppose
http://kansascity.craigslist.org/car/623758634.html
Old 03-31-2008, 06:40 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
If you keep looking 6,500 should get you a really, really nice example. And your right, if he negelects to mention a huge tear in the drivers seat what else is he not telling you. Find one with lots of recent service items in mint condition and it will be well worth the money.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 03-31-2008, 07:10 PM
For 6k you may even find a 944 Turbo
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 03-31-2008, 07:16 PM
Going out on a limb here....does this mean you are not doing a PPI?
Yeah, keep looking, they are around.
Tom
Old 03-31-2008, 11:22 PM
If failed the PPPI.
Old 04-01-2008, 03:27 AM
meister member
speedracing944's Avatar
Originally Posted by Objectionable View Post
If failed the PPPI.
LMAO
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-01-2008, 06:00 AM
white944cup's Avatar
If you are still in the market, this is one of the cleanest looking 944 Turbos that I have seen for sale on the forum in a while, and it's in your price range...no personal affiliation BTW. Don't be afraid of a Turbo.....they are not that much more expensive or complex that the N/A, and they are better cars in almost every performance category. If I was still looking, I would be all over this one. It's a great color combination and it looks to be in excellent condition and unmolested.
FS: 1986 944 Turbo $6700
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 04-01-2008, 09:24 AM
Thanks for the heads up - I sent email.
I'm concerned about the number of miles - valid concern?
Old 04-01-2008, 09:40 AM
