Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Froze Wheel Bearing
uh oh. so im attacking that odd sound on my RF wheel. i bought new bearings and have the wheel off. i cant get the rotor off. tips, tricks?
im standing by.
p.s. - this would explain why the guy was insisting i take the extra spindle he had laying around.
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 04-15-2008, 11:20 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
front?
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-15-2008, 11:37 AM
Rockin' NW Arkansas
yes
Matt
Old 04-15-2008, 11:48 AM
You got the retaining screw out right? And the caliper off?
http://www.clarks-garage.com/shop-manual/susp-08.htm
86 Metallic Grey
Old 04-15-2008, 12:35 PM
If all the other retainers are off (screws, calipers, brackets) then you could try to apply some pressure at the rear side of the rotor with a screwdriver (pry towards you) while tapping on the hat (hub section) wiht a hammer. This should loosen up any stuck bearings unless they are melted to the spindle.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 04-15-2008, 02:33 PM
Rockin' NW Arkansas
update. i tried it all. i put it all back togeather and will go down tomarrow to get a puller. if that doesnt work, there is a shop that is walking distance away. i will take an extra rotor, bearings and spindle. they said they never worked on a porsche, but if its just a bearing they can most likely get it off..... for up to $200. when i was tapping and banging, i must have knocked something loose. the wheel no longer makes the sound and turns rather smoothy.
im not going to settle for that. i will get this fixed.
Matt
Old 04-15-2008, 03:53 PM
Back from Beyond
Odd. Remove wheel, remove caliper, knock off dust cap, remove clamping nut, slide hub off. Take hub to work bench, remove nuts/bolts holding rotor onto hub, knock rotor off. What did I miss that would cause the rotor to hang up? Even if the bearings are in really bad shape the spindle is tapered, and the hub shouldn't require too much beating.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 04-15-2008, 09:14 PM
