Half axle diameter
Just ordered a new CV joint assembly. Looks good except the half axle is much thicker than expected. By about half an inch corcumferance than what's on the car. I have reason to believe at least on CV has been replaced. Maybe the axles that were on it were both undersized or the new half axle is too thick. Are there models of this half axle with a bigger diameter? Is it ok to mix the two?
Old 09-21-2018, 06:21 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by Aerodynamic View Post
...Are there models of this half axle with a bigger diameter? Is it ok to mix the two?
Yes, there were different half shafts, and
No, they should be both the same.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 09-22-2018, 04:04 AM
Where can I find another smaller half shaft?
Old 09-22-2018, 06:13 AM
9FF 9FF is offline
9FF's Avatar
It would help if you told us what model and year car you have, 924, 944, 951, 968?
However why not give our host (Pelican) a call, they’ll have the correct one for you. You’ll still need to give them the year and model of your car though.
Mike A
Old 09-22-2018, 07:04 AM
My bad. It's a 1987 924s.
Old 09-22-2018, 07:45 AM
im not totally sure but i think its supposed to be 100mm diameter, 33 spline shafts, 21.xxx" long.
Old 09-25-2018, 10:55 AM
