Kevins911's Avatar
Balance shaft delete on a street engine, bad idea?
I am in the process of rebuilding my friends '84 944 engine. I've heard about race engines with no balance shafts, would the extra vibrations shorten the life of the engine? How much harsher would it actually be?
Kevin
'73 914 2.0L
Old 04-17-2008, 06:52 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
You mean no balance shaft belt right? Your not going to try and remove the balance shafts are you?
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-17-2008, 07:02 PM
Kevins911's Avatar
No belt would be the easiest, but i was thinking of removing the shafts completly and fabing up some block off plates....with no shafts I'm thinking I could have issues with oil pressure though, would I?
Kevin
'73 914 2.0L
Old 04-17-2008, 07:06 PM
Eldorado's Avatar
your girlfriend will love you for it...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-17-2008, 07:15 PM
Why must we have these anyway**? What do other straight fours do about vibration. What other motors use them? I don't recall vw using them...nor do I recall their motors vibrating themselves apart.
**bitter cause balance shaft bearing failure destroyed my last engine.
WARNING: Do not buy from Ron Kirby of Fort Thomas, KY (currently RRRacing1970).
Old 04-17-2008, 10:53 PM
Burn the fire.
Brando's Avatar
The engine doesn't vibrate itself apart on most other cars. They do certain things to dampen the vibrations as much as possible... such as softer engine mounts, weight the crank differently, dual-mass flywheels, etc.
Porsche licensed the balance-shaft technology from Mitsubishi. It was not necessary, but helpful when considering comfort for the driver and passengers. Recommended for a street car, optional for a track car.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 04-17-2008, 11:15 PM
Kevins911's Avatar
On second thought I'm just going to leave them, I was just trying to simplify the engine. It's probably more work than it's worth for no real gain, well except a harsher ride!!
Thanks for the info guys!!
Kevin
'73 914 2.0L
Old 04-18-2008, 12:57 AM
meister member
speedracing944's Avatar
worth 7 hp.
May cause vibration at a certain frequency which will decrease the fatigue life of components which would cause premature failure.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-18-2008, 01:39 AM
Most four-bangers are smaller than the 944.
The 2.5L...going up to 2.7L and 3.0L are very big for 4-cylinder engines. The VWs go up to about 2.0 (maybe 2.1).
Heavier pistons and rods and everything else that rotates cause more vibrations.
"I Am The Stig!"
MistahSinclair
1986 N/A Daily Driving Project!
Old 04-18-2008, 04:14 AM
