strath44's Avatar
Air flow meter fix / refurb
Not sure if anyone has seen this on you tube, but it helped me!
http://www.youtube.com/watch?v=-11J8XawQtc
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 08-24-2009, 08:07 AM
winter-hater club member
nynor's Avatar
excellent video. thanks for posting that.
"COOL PRIUS!" - Nobody Ever
Old 08-24-2009, 11:45 AM
Redline Racer
HondaDustR's Avatar
glad it did. I've gotten many messages on youtube about it from all kinds of people with Motronic cars. I wanted to make part 2, which would go through the easy way to test the sensor and the wiring, but my camera's broken.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-24-2009, 01:19 PM
strath44's Avatar
thats a pity would be interesting to see that.
A fair few people must just this as a cause of rough running at certain points in the rev range?!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 08-24-2009, 01:35 PM
Send a message via AIM to ScoobySteve
That's you?
Redline Racer
HondaDustR's Avatar
Originally Posted by ScoobySteve View Post
That's you?
Yup.
I would be making an engine rebuild highlights video, too, but no camera...
Old 08-24-2009, 01:53 PM
Proprietoristicly Refined
John_AZ's Avatar
Nice work HondaDustR!
Here is a companion video---
Good work.
John_AZ
Old 08-24-2009, 03:38 PM
Redline Racer
HondaDustR's Avatar
Haha! That one was cool, since the camera wouldn't quite fit with the air filter in place, so I did a "dry" run up and down the main street. Car sounded totally awesome, just like it had a good exhaust on it. I was interested if the AFM would actually hit the fully open stop at max revs, but it didn't. I later found out it wouldn't matter if it did or not for fuel metering purposes, since the WOT map on the Motronic is 1 dimensional and only uses the rpm signal. Good way to know you have a vacuum leak, clogged injector, clogged catalytic converter, bad fuel pressure regulator, or something like that, 'cause it will be injecting fuel assuming the engine is working well, since it doesn't even use the O2 sensor at WOT. It will run like crap if anything is off.
Old 08-24-2009, 07:16 PM
Back from Beyond
www.frwilk.com has a lot to say about the AFM refurb. I did mine a few years ago based on F.R.'s info. An easy, fun little job and an improvement for the car, too.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-25-2009, 12:07 PM
