Can't Close Hood?
Title pretty much says it all... the hood won't close.
I've been gone for a week, and when I popped the hood to have a peek inside last night everything seemed fine. I go to close the hood and only the secondary latch engages. The cable isn't broken - it springs back and forth freely. How do I go about fixing this thing? I'd like to get this taken care of; I plan on putting the car up for sale soon since I just don't have enough time these days to give the car the proper attention it needs.
'87 924S (Sold) |
That Guy
Make sure the main locking tab releases freely when you pull the cable. If it doesnt, clean the area with brake cleaner (or whatever) then relube with white lithium grease.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Will do... from what it looked like late last night it seems like the part that holds it in isn't going back where it's supposed to go. I tried forcing it back without any success and shot the area with spray-on lithium grease. When I have a look this afternoon it won't be nearly as dark as it was at 11:00pm.
'87 924S (Sold) |
Make sure you are not hitting on your headlight
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
Parrothead member
Check the rivets that hold the latch to the radiator support. Two of mine broke and I lost my hood on the highway when it flew open.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Figured the stupid thing out finally. I had to remove the rivets that hold the latch on and operate on the latch itself. It's held together with metal tabs, and over time they started to loosen and the catch moved out of place. Bolted it back on and it's good as new. For what it's worth, it looks like one or two of the aluminum rivets were getting close to the end of their life. The factory should've just used self-tapping bolts...
'87 924S (Sold) |
