Eldorado's Avatar
968
if the right 968 came along, would you take the plunge?
I'm starting to get the itch.... and with school bills out of the way now and forever, i might be able to afford one! lol =P
what should you look for in a good example of a 968? with 944s i know things like front engine service, clutch, LSD, etc...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-23-2008, 11:16 PM
PRMN944
I read some articles from Excellence magazines, the 968 is the way to go compare to 924S and 944s.
The 968's maintenance is far less hassle. For example, the timing belt service is
required every 60K miles.
With 924S and 944s , after installing the new timing belt, it requires to adjust about 500 miles or 1500 miles with special factory tool. Then , about 15K miles
you need to adjust again. New timing belt about 30K miles.
Engine overheat is another issue.
As for the what to look for , may be maintenance records, salvage title, mileage, and fluid leaking. Almost all 968 has good home and well care for.
Old 04-24-2008, 01:10 PM
Just a quick note on the 944/924S belts.
The later cars... 1988 as I recall had the auto tensioner so no need to check it over and over. Replace it and go 30K.
968 is a sweet ride but I have heard that the transmissions can be a bit weak if you were to put it on a track.
Also the early cars had an issue with the pinion bearing which Porsche discovered and remedied but if you are looking at a 1992 you should make sure it was not one of the suspected cars with out the fix.
82 924 restored, 83 944 parting out
In search of 1988 or newer nice 944.
Old 04-24-2008, 06:44 PM
Eldorado's Avatar
very good point, thank you!
Kyle
Old 04-25-2008, 07:20 AM
My 944 scares adults
lovemy924S's Avatar
Send a message via AIM to lovemy924S
I think it was 87 and up, pretty sure because my 87 has it...i've also heard that the auto tensioner is pretty good, but not perfect and the tension should still be checked with a tensioning tool?
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers
1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?)
Old 04-25-2008, 10:14 AM
Eldorado's Avatar
ya that's what i've heard too...
Kyle
Old 04-25-2008, 10:55 AM
PRMN944
To Eturbo924, thanks for the inputs. I stucked with this 1983 944 for long
time. I thought all 924s and 944s timing belts were the same.
Old 04-25-2008, 12:05 PM
Tidybuoy's Avatar
If I had the money, I'd buy a mint 968 and transfer the suspension, engine, and drive train into my 944.
My personal preference is that the 944 looks better even if the 968 is better.
Vern
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 04-25-2008, 02:25 PM
Greasy Member
many944s's Avatar
If you are REALLY looking, there is one for sale here in town. I can get pictures and more info for you if you would like. I a in NO way affiliated with the car, I just saw it for sale a couple of weeks ago, and my wife would kill me if I bought another car right now!
Let me know!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 04-25-2008, 02:27 PM
white944cup's Avatar
Vern:
There's a 968 engine with 89k miles for sale on the parts forum for $3500, which is a pretty good deal....I have seen a 944 conversion with the 968 motor and 6-speed trans running on a track, and I can tell you that it make a very fast car....a real sleeper.
968 engine complete 89k miles
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 04-25-2008, 03:17 PM
F944S's Avatar
I agree with Vern, the 944 looks better.....
Fred
'87 944S
'87 325 IS
'01 Grand Cherokee
'74 Kawi 750 H2
Old 04-25-2008, 05:18 PM
Eldorado's Avatar
hey Nick, I wont seriously be looking for a month or two... my 944 is in need of some major tlc, so i'm thinking of buying a beater (1992 golf diesel... any objections anyone? price is 1500, new clutch, new ball joints, new calipers) until I finish getting the funds together to put towards the 968.
Kyle
Old 04-25-2008, 05:33 PM
meister member
speedracing944's Avatar
The tensioner is not an auto tensioner per say but a spring loaded device which places tension on the belt and you lock it down into position. As the belt ages and stretches it will loose tension and you need to go back in and release the tensioner, allow it to place tension on the belt again and then lock it down once again. It is recommended that you double check the tension using a P9201 especially when installing a new belt due the spring tensioner not being able to apply the correct tension on a 'new' belt.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-26-2008, 06:22 PM
Tidybuoy's Avatar
Originally Posted by white944cup View Post
Vern:
I you read my post it starts with "If I had the money" Unfortunately, I don't have any right now. Until then, I just get to dream about it.
Vern
Vern
Old 04-27-2008, 11:16 AM
I used the term Auto tensioner because I did not know the official term for it.
I do believe they were standard on the 1988 models but not the 1987s. It very likely could be that the last few of the 1987 944 could have been fitted with them. Porsche did this quite a bit... that is put a new feature on 1/2 the way through the year.
On the checking tension issue on the 1988 and newer cars. I spoke with my mechanic some time ago. (works on Ferrari, Porsche, Lambo, Lotus, BMW, Mercedes and more) When I told him to go in and check the tension on my friends 944S2. He told me that in his experience (which is vast he is no smuck mechanic) the spring loaded tensioners do an excellent job of keeping tension on the belts for 30K miles. That said he still checked the tension for me :-) and it was perfect at 15K miles.
Anyway I would say the 1988 and newer cars had less worries on the belts than the early cars... agreed? That was really my point.
As they always say... get the newest and best shape example that you can afford. In Porsches case they always made the next year better than the one before it. Frequently changing little things with out making note of it.
Oh and if you like the looks of the 944 over the 968 just get a 944S2. It has almost the same performance with the 944 (if turbo) body.
My friend has his for sale now. $8750 with the optional sport suspension and brakes.
Old 05-03-2008, 03:46 PM
Eldorado's Avatar
i wouldn't agree, eturbo.
as previously said, the tensioner will keep the tension on the belt.. .but when it's tightened down, it doesn't take into account for the belt stretching and geting 'broken in'... so you've gotta loosen it again, let the spring tensioner do it's thing, then tighten it back down again.
at least, that's my understanding of how it works.
the spring doesn't keep tension on the belt at all times... you tightening everything down keeps tension on it.
Kyle
Old 05-03-2008, 07:26 PM
Deplorable Member
Porsche-O-Phile's Avatar
Parts are a helluva lot cheaper for a 944. Look at a water pump. I rest my case.
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 05-03-2008, 07:44 PM
Custom User Title
Dave L's Avatar
I would go for an S2. I dont really love the look of the 968 and would rather avoid the complexity of a 951. In all seriousness I would also look at a Boxster
Old 05-04-2008, 05:02 AM
flash968's Avatar
to clarify any issues regarding the 968 transaxle, it is actually a stronger box than the 944 boxes, and can handle a lot more torque - the gear spacing can be a bit much though for guys who run smaller tracks
the pinion bearing issue is not as prevalent as some would like you to believe - while it is unusually common for any problem in a car, and after watching this closely for the last 5 years, it does not appear to be in more than about 5% of the cars - it is not limited to any particular year - is not more common in any particular year - it is NOT related to mileage - it can happen at any time in any car - the problem arose due to a combination of casting tolerances, and the assembly procedure being an automated one - this resulted in the preload setting on the bearing being too high on some of the units
repair is usually about $1500
semi-related upside is that the clutch job on the 968 is only about 4 hours - unlike the earlier cars, you do not have to drop the transaxle to do it
as for the looks, that one is very subjective - while i prefer the 968, i do think the S2 front end is more aggressive looking, in spite of the more dated look - i have subsequently made some changes to the front end of my 968 to make it more aggressive looking
i have seen a couple of S2s with 968 rear clips - nice
Old 05-04-2008, 06:29 AM
Eldorado's Avatar
i'm in love with the looks and uniqueness of the 968..
that's why i originally wanted the 944... i didn't want to be 'just another 20-something with a honda'... it was unique to me.
but the s2 is a very nice car as well..
Kyle
Old 05-04-2008, 08:52 PM
