Fans don't come on!
all last summer to cool the engine down i had to keep watch on the coolant gauge and when she got to hot i had the turn the A/C knob to turn the fan(s) on. Plus i forgot a few times and let it get to hot for a few minutes. I'm not dealing with that this summer! Pain in the ass!
I'm guessing my Aux Fan switch on the rad is no good??
I should probably run with a thermostat this summer too eh? lol
but still, the fans should come on when it gets to hot.
Next time i forget i'll cook the engine, it only takes once to boil over and the engine is toast. Not worth it!
Old 04-24-2008, 03:09 PM
Just thinking out loud
mattdavis11's Avatar
Yep, to test if it is the switch that's bad, jumper the connector, the fans should come on.
91 FJ80
84 Ram Charger (now gone)
Old 04-24-2008, 03:36 PM
There are two control inputs to the radiator fan relay. One from radiator thermoswitch and the other from the A/C. If the A/C turns on the fans, you know what's the next suspect.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-24-2008, 03:54 PM
Perfect. I'll order one up. it's only 10$
Old 04-24-2008, 05:02 PM
