-   -   Permanently Disabling the Alarm Module (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/405780-permanently-disabling-alarm-module.html)
Paul_Heery 04-24-2008 03:10 PM
I was troubleshooting a no start problem on my 1986 951. I narrowed things down and using the Alarm System - Bypassing procedure from Clark's, I was able to get the car to start every time with no problems.
Now, is there any way of permanently disabling or removing the module? Or should I just look for a replacement? The bad one that is in there now keeps ticking. It was doing this before I started the procedure. It sounds almost like a turn signal indicator and it's driving me nuts.
944 Ecology 04-24-2008 04:08 PM
When you follow the directions in Clarks Garage, you are supposed to remove the module from the car completely. Just jumper the cables going to the module.
Paul_Heery 04-24-2008 04:25 PM
Thanks George. That did it.
