Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Uh oh. First Roadblock...
Okay, so I'm finishing up my head gasket job and am to the final stages. I was venting and filling the coolant system and discovered a coolant leak coming from the back of the engine. It's running down and off both sides of the block. What did I forget? Any ideas where specifically it's coming from? It's tough to tell without taking the intake off...
In one of the below pics, I drew red arrows to show where the most coolant is running down the bottom of the engine
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 04-27-2008, 12:34 PM
That Guy
Techno Duck's Avatar
Make sure you close the bleed screw. Its probably leaking across the cylinder head. Ask me how i know.. .
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-27-2008, 12:59 PM
Writer/Teacher
CJFusco's Avatar
I'm kinda thinking it's something to do with the rear water pipe, next to the cycling valve... but I'll check the bleed screw first.
Old 04-27-2008, 01:11 PM
winter-hater club member
nynor's Avatar
that is my first guess. i always use RTV along with the gasket on that one.
"COOL PRIUS!" - Nobody Ever
Old 04-27-2008, 01:38 PM
Writer/Teacher
CJFusco's Avatar
Yup, one of the bolts holding the rear water pipe to the head wasn't tight enough. Great. Just added another few hours to my job...
Old 04-27-2008, 01:45 PM
nynor's Avatar
hours? why?
Old 04-27-2008, 06:31 PM
Writer/Teacher
CJFusco's Avatar
Have to take the intake back off... plus, that bracket is a beyotch.
Old 04-27-2008, 09:39 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
Thats better than getting coolant in your clutch and then having to do that job. If you thought the HG was a challenge the clutch would be hell.
Keith
1986 Porsche 951
Old 04-27-2008, 11:24 PM
Writer/Teacher
CJFusco's Avatar
How did you get coolant in your clutch?!?
Old 04-28-2008, 06:55 AM
nynor's Avatar
the coolant runs into the window on the bell housing, i would guess.
i always try to put the water neck and bracket on the head before installing the head back on the block because it is such a pain.
Old 04-28-2008, 08:24 AM
Writer/Teacher
CJFusco's Avatar
Yeah, I wish I thought of that. It literally took me HOURS to get those two frickin bolts back onto the assembly with the head still in the car.
Old 04-28-2008, 02:25 PM
