Eldorado's Avatar
rear axle nut
damn, people aren't kidding when they say that nut is tight.. it's much tighter this time than it was the last time i had it off...
i got a 4 foot iron bar on there and it didn't budge..
I'd drive the car to a shop to have it loosened, but my new dme relay isn't here yet..
boo to owning a stubborn car..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-30-2008, 12:15 PM
Slip a steal pipe on over your breakerbar. Then have it set up so you can unjack your car on to pipe.. slowly and from good cover. Huge torque... Lefty loosey.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 04-30-2008, 10:29 PM
What JivenJim is trying to say is, use a huge cheater on the nut, jack up your car and position the breaker bar so that as you lower the car it loosens/breaks the nut free.
Are you swearing in the right language?
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 05-01-2008, 01:27 PM
That Guy
Techno Duck's Avatar
This is what it took to get the axle nut off on my friends '89.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-01-2008, 04:24 PM
I try to conserve my energy.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 05-01-2008, 04:28 PM
6' pipe extension and you stand on it. 6' x 160lb= 960ft-lb. Worked for me. OSHA is reviewing....
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 05-01-2008, 04:43 PM
Hey duck,
Did you have a 3/4 drive on that 7 ft bar. I snaped my 1/2 drive adapter doing it that way. I guess I should of bought the pro grade socket set.
As an alternative, I marked the spring plate position and took my whole trailing arms in to a buddies shop to do my last set of bearing. Best $150 I spent. Easy to do with hydrolic press and impact hammer (like bazar had)
Old 05-01-2008, 09:16 PM
That Guy
Jim, i was using a 1/2 inch driver socket. The breaker bar looked like it was going to shatter when i applied full force onto it.
Jon
Old 05-02-2008, 08:25 AM
