Random Intake Banjo Bolt question
On the 951's Intake Manifold there is a banjo bolt, to which connects a vacuum line running to the KLR and a vacuum line that connects to several others running along the bottom of the intake (also connects to the FPR, the damper, and out to the BOV).
Does it matter in which order these two connectors are placed on the Banjo Bolt? I'm guessing not... |
Nope. As long as everything gets connected to a source of boost / vacuum, your fine.
That's what I figured, thanks.
| All times are GMT -8. The time now is 03:37 AM. |
