| mr.944 |
05-07-2008 10:38 AM |
new member here. need help.
Okay My car is a 90 944 S2 Cab. It takes fits were it won't start. I thought that it was the DME relay so I got a new one, it did not help. I was desperate when It left me stranded at 11 at night so I removed the cover from the dme relay and held down the contacts, the fuel pump started to run and the car started right up. Okay so what I think is when I turn the key on and start cranking something isnt letting power go to the relay to let the pump run. But what? the ignition switch could be bad? I even unplugged the alarm module, what about the DME itself? The tach neddle does jump when I cut the key on so the ref sensors should be okay, right? The car has been doing this for sometime now but it has gotten way worse after I let it set for a couple of weeks. I have checked every single ground, every electrical connection, I'm at a loss now. PLEASE some one work a miracle!!
